jdong's initial Braava Jet 200 impressions
Re: jdong's initial Braava Jet 200 impressions
Postby Kazy » March 31st, 2016, 4:00 pm
Thanks, that what I needed to know.
Kazy
Postby kondi » May 19th, 2017, 3:10 pm
jdong wrote: - Wet Mopping pad: ABSOLUTELY NOT. The cleaning cycle sprays a lot of water at the beginning of the cycle (as if to wet the pad), then sprays less water. Even if you only clean a 50 sq ft area the first time, using the same wet pad and restarting the cycle is guaranteed to leave you with a sopping wet floor. Probably not what you want.
- Damp Mopping Pad: Maybe. The same observation as above applies, the unit sprays more water at the start than at the end. But I've been able to use the same damp pad for two bathrooms, though the second bathroom ends up being slightly more damp than the first, though not unreasonably so.
Did you know you can change the amount of water spayed for the different type of pads by using the bluetooth app? It can be useful for the pad reuse and to not make your floor sopping wet.
kondi
Users browsing this forum: FlyingPolarBear, fuzzydunlop, jdong, lanchez, leonicholson, magura, Miles267, Panache, Rar9 and 343 guests
