Braava 380 charge problem
PostPosted: March 1st, 2019, 7:41 am
by jorgeli
Hi
My braava 380 is working good for many years now.
But the last times the charging not work good.
It charge about 10 min and then it makes noice and the led blinking red and blue.
I do a reset when hold the power button for 10 sek and then it charge for 10 min again.
I must do this about 20 times before it is full and then it is ok.
Have try new battery twice but the same result.
Even try different orginal power adapter.
Is it someone that have a good solution for this?
Regard J├Ârgen
Re: Braava 380 charge problem
PostPosted: May 5th, 2019, 5:53 pm
by TechGuy
If you are still using the same battery from day one, did you try a new battery?
