Samsung SR8849 no power
Postby zekicker » December 9th, 2016, 7:36 pm
My robot does not power on and does not charging when on the base and the green light is on.
I can heard a clicking noise from the base I think.
I change the battery.
I didn't see dry joints from what I see.
Can you help me to investigate ?
Thanks.
zekicker
Re: Samsung SR8849 no power
Postby Elektronics » August 25th, 2017, 12:10 pm
Your main board is done if it clicks. Main Board was overheated because of battery charge.
90 % of all failures on the navibot's is the main Board getting overcooked
https://ibb.co/cubhE5
https://ibb.co/i9CHgk
Those images is from a Navibot that click and no light in display what so ever
Elektronics
Postby machj » October 19th, 2017, 12:00 pm
Look at this:
viewtopic.php?f=22&t=18485&mobile=on
http://2ww.makeupguides.net/cw3MkStepsj ... oblem.html (read a discussion)
http://www.ebastlirna.cz/modules.php?na ... ic&t=70660
It could be a power switch, 8 MHz resonator (try to replace or add a 22-60pF capacitor as described under the video) or you can replace a capacitor CE1 ...
I have the same problem, SR8845 is in a service now. I expect that the result will be "wrong motherboard, buy a new one" - but it could be repaired with a cheap capacitor as mentioned above.
machj
Postby styxxx » January 14th, 2019, 4:15 am
Could you solve the problem?
My SR8825 has the same symptoms. I checked the main board, no visible damages. Main switch is fine and I was able to meassure voltage on the board (voltage matches the markings, saying 3.3, 2.8 and 5V). But I don't know what else to test.
The station ticks every 1 sec and drops the voltage. Even if I remove the battery.
styxxx
Return to Samsung Robots
Users browsing this forum: im1kissfan, johnnyh, magura, Metalworker, vic7767 and 374 guests
