**** O'Tool/CPU32/A Rel:3.57 SN:0000 T+ Dec 21 1994 CCC68k 1.2 ****
Trilobite TM (c) Copyright 1995-2004 Electrolux AB
Revision voltage 1106 mV HW 3 16 bit FPROM
Software revision:
113105401 r05
Software date:
070529 09:57:02
Compiled by Peter Dahl Electrolux FCLA AB (VM)
60 kHz Dual Band 8 Channel Sonar
Power on (batt2): 384 times.
Fan/brush 128:59 hrs. 400 380 charge cycles.
Revision ID 1106 seed 881215
OEM option: 0
RTC option: 1 (1:0)
Previous shut down cause: 18
Map search disabled
Temp batt 1 23.11C
Temp batt 2 22.75C
Motor voltages OFF 19.34 0.02 18.54 5.59 5.57 5.58 5.55
Enter main loop
UBAT: 19.4 V 19.3 V. U_CH: 18.7 V Lifted!Formatting transmitter band:
1472 027 1322 029
Start following wall
Track width 0 0 0 0 mm
Obstacle at -67 deg 2 cm
Starting wall trace (0 s) condition: 0
Batt2 low (3 s)Temp batt 1 20.95C
Temp batt 2 19.85C
, charger exists
Motor voltages OFF 19.72 0.16 18.92 5.76 5.75 5.75 5.73
Motor voltages ON 19.69 10.30 10.12 13.44 13.48 13.47 0.07
Power on (batt1): 400 times.
Fan/brush 129:01 hrs. 400 380 charge cycles.
Revision ID 1107 seed 667468
OEM option: 0
RTC option: 1 (1:0)
Previous shut down cause: 15
Map search disabled
Temp batt 1 21.35C
Temp batt 2 19.86C
Motor voltages OFF 19.59 0.02 18.80 5.76 5.75 5.75 5.72
Enter main loop
UBAT: 19.6 V 19.5 V. U_CH: 19.0 V Lifted!
Motor voltages ON 19.56 10.30 10.03 13.44 13.48 13.47 13.44
0344 008 0199 007
Obstacle at -50 deg 5 cm
Found fence, following it
Users browsing this forum: vic7767 and 116 guests
