Driving roomba using an Android phone
Re: Driving roomba using an Android phone
Postby vic7767 » March 12th, 2012, 9:16 pm
Once you have set the baud rate to 57,600 and saved the setting you should not have to enter $$$ and get the CMD prompt from the Bluesm1rf again. The 110 Dirt Dog should be sending out the same charging data that your 4130 is sending as long as it is connected to either a home base or a power supply unit.
Postby rwb214 » March 12th, 2012, 9:52 pm
vic7767 wrote:Once you have set the baud rate to 57,600 and saved the setting you should not have to enter $$$ and get the CMD prompt from the Bluesm1rf again. The 110 Dirt Dog should be sending out the same charging data that your 4130 is sending as long as it is connected to either a home base or a power supply unit.
That's what I figured. The 4130 gives the charging info, the dirt dog isn't in this case. Could there be an SCI issue on the dirt dog
EDIT: Nevermind, now I'm not getting charging info from either roomba! :-(
rwb214
Postby mfortuna » March 13th, 2012, 1:14 am
I have not had issues getting charging info from the Dirt Dog using BAM or my reds using a Basic Stamp that was programmed to bridge SCI commands to a BT module.
It seems like you need to solve your issues with BT and then you can go to the next level.
Postby rwb214 » March 13th, 2012, 7:08 am
mfortuna wrote:It seems like you need to solve your issues with BT and then you can go to the next level.
That's what I'm thinking. I ordered a bt dongle, should be here this week. Hopefully ill be able to do a little more from the PC than from the android.
Thanks for the ongoing help I'm getting from everyone with this, I really do appreciate it.
rwb214
Postby SE_machine » July 5th, 2012, 11:58 pm
Has anyone found a fix for this or happened to get a bluesmirf working with the android app? I just ordered a bluesmirf to use with the app and hope it wasn't a $40 mistake. The chip comes with 115k baud rate default, which should let it work with the 500 series, no problem. In the app, there is a setting for Create compatability, which I think changes baud rate somewhere. I would try this and see if it fixes it. Also, I heard CTS and RTS need to be shorted on the smirf (see schematic on hackingroomba page).
Tim - 3 unmodified Disco SE's since 2005
- Roomba 570 with DIY Rootooth (BlueSmirf Silver) and "Roomba Touch Drive" Android App.
- A used Scooba 5900 as a Christmas gift to my Mom. Fixed with TV remote IRED, OSMO soon.
****- 500 series' owners, Check out my poll at viewtopic.php?f=3&t=11144&start=0&view=viewpoll
SE_machine
Postby mfortuna » July 6th, 2012, 6:34 am
I will try an updated version of this app on my security dawg (dirt dog with BAM) tomorrow. Not a bluesmirf but it will be a data point.
I don't think RTS and CTS need to be tied together since hardware flow control is not used.
Postby RobotMan_24 » July 10th, 2012, 3:09 am
Here is another app to control your Roomba for the android phone:
http://www.robotappstore.com/Apps/Roomb ... 4C62D049A9
RobotMan_24
Return to Robotic Hacking
Users browsing this forum: mfortuna, vic7767 and 142 guests
