Driving roomba using an Android phone
Re: Driving roomba using an Android phone
Postby mfortuna » March 7th, 2012, 8:49 am
Nice project. Although I don't identify which pins are which, pictures in this thread show how to get TX, RX, and GND off the SCI board connector.
viewtopic.php?f=4&t=10709&start=40
Once you open up roomba you will see a big 3 pin regulator(probably a 7805) where you can grab 5V. I didn't take a picture but that is how I got 5V for the BAM.
Postby rwb214 » March 10th, 2012, 11:21 pm
rwb214 wrote:I'm working on building one of these: http://hackingroomba.com/projects/build-a-roomba-bluetooth-adapter/
Well I've got this thing assembled according to the plans now and I'm able to pair it with the phone via bluetooth, connect to it in the Android app, Roomba Touch Drive, but the robot does not move. I don't know if it's noteworthy, but I'm using the Bluesmirf Silver (RN-42), a newer version than what was used in the original. Perhaps I need to connect to it with a PC first and set the baud rate? I don't really know where to begin other than checking and rechecking all the connections...
rwb214
Postby vic7767 » March 11th, 2012, 12:08 am
What model Roomba are you using? The 4XX, 4XXX, and Dirt Dog use 57,600, N, 8, 1 while the 5XX, 6XX, and 7XX use 115,200, N, 8, 1.
Postby rwb214 » March 11th, 2012, 7:50 am
I have a dirt dog and another 400 series roomba, and I can't get it to work on either. How do I configure the bluesmirf?
rwb214
Postby mfortuna » March 11th, 2012, 8:04 am
If you have a computer with bluetooth you may need to use a terminal program to change the baudrate. Here is one thread on the subject:
viewtopic.php?f=4&t=15709&hilit=rootooth+baud
Postby rwb214 » March 11th, 2012, 12:07 pm
That's what I figured, I have to pick up one of those Bluetooth USB dongles and connect it to my PC. Thanks for the response, I'll come back here after I give that a try.
rwb214
Postby mfortuna » March 11th, 2012, 2:28 pm
I just had a thought. Does Android market have a terminal emulator program for bluetooth? You could do it from your phone if that was the case.
Postby TechGuy » March 11th, 2012, 3:03 pm
SENA BTerm Bluetooth Terminal
https://play.google.com/store/apps/deta ... sena.bterm
BTW, Google Market has been renamed to Google Play a few days ago.
Postby rwb214 » March 11th, 2012, 3:45 pm
Funny, I just thought of that too and download SENA. I couldn't program myself out of a wet paper bag so could someone please explain to me, very slowly, what I need to do in SENA?
Thanks!
rwb214
Postby mfortuna » March 11th, 2012, 5:01 pm
This quote from vic7767 may be what you need to do:
The Firefly comes loaded with the default baud rate of 115K. The is a configuration time that will timeout after 60 seconds and no other changes will be allowed via input commands. Your first task is to change the Config timer from 60 seconds to forever (255). Power up the Firefly, establish a connection via your PC, type $$$ and receive the CMD prompt. Type in "ST, 255" without the quotes to change the Config timer to always on. Then type "SU, 115" to set the baud rate. Then type "---" to escape the command prompt. Now you should be able to monitor the charging data from your Roomba as I mentioned earlier.
Postby rwb214 » March 11th, 2012, 8:04 pm
All I get when I run SENA on the Android is something that looks like a command prompt, but it doesn't display anything (text) I enter (even though it is logging it). I was able to do a bluetooth pairing with the rootooth attached to the roomba in SENA and I entered some of the commands listed above, as well as some that I found here: http://www.sparkfun.com/datasheets/Wireless/Bluetooth/BlueSMiRF-v1_1_rev2.PDF . When I go back to the Roomba Touch Drive App it's the same as before.
BTW the RTD app tends to freeze a lot while trying to connect, and has about 10 failed connection attempts for every successful one...
rwb214
Postby rwb214 » March 12th, 2012, 11:23 am
Ok here's my current status tinkering with this thing... I'm figuring out some of the the commands in SENA and Blueterm; D displays the currents status, H displays all the commands. I entered a SU,57 command and that appeared to have changed the baudrate to 57.6 under the status. I then changed the baud rate to raw by entering ZU,57.6 and I started to get the charging data, refreshed every second, from the roomba. I exited SENA, reset the bluetooth connection, connected to it in Roomba Touch Drive, Still no motion from the robot! I thought I had changed the baudrate to 57600... how else can I debug this?
rwb214
Postby vic7767 » March 12th, 2012, 11:59 am
Does the Roomba Android app have any way to set the baud rate?
Postby rwb214 » March 12th, 2012, 12:27 pm
Also, now I can't replicate whatever I did to make it display the charging info...
rwb214
Postby mfortuna » March 12th, 2012, 1:12 pm
I don't think you need to reset the BT connection when you go from SENA to the driving app. Maybe resetting caused the rootooth to revert to it's original settings? If you look at tht thread I provided a link for you will find a way of saving the settings so they are permanent.
Postby mfortuna » March 12th, 2012, 1:15 pm
vic7767 wrote:Does the Roomba Android app have any way to set the baud rate?
Good point. Franky added 57,600 support when I mentioned my create didn't work with the original app. I never tested it but it should work fine with your roomba.
Postby rwb214 » March 12th, 2012, 1:27 pm
mfortuna wrote:I don't think you need to reset the BT connection when you go from SENA to the driving app. Maybe resetting caused the rootooth to revert to it's original settings? If you look at tht thread I provided a link for you will find a way of saving the settings so they are permanent.
The Bluetooth connection has been very finniky, I'm finding it necessary to unplug the rootooth, turn off Bluetooth on the android, turn on Bluetooth on android, start the app, plug in the rootooth, and initiate the Bluetooth connection from the android. Then and only then will the android connect to the bluesmirf ...
rwb214
Postby TechGuy » March 12th, 2012, 1:42 pm
rwb214 wrote:...The Bluetooth connection has been very finniky, I'm finding it necessary to unplug the rootooth, turn off Bluetooth on the android, turn on Bluetooth on android, start the app, plug in the rootooth, and initiate the Bluetooth connection from the android. Then and only then will the android connect to the bluesmirf ...
If any application exits without closing the port, that port will be locked until that port is reset.
Postby rwb214 » March 12th, 2012, 3:32 pm
TechGuy wrote:If any application exit without closing the port, that port will be locked until that port is reset.
So by "disconnecting", should that close the port? When I do that the LED's on the Bluesmirf indicate that it is visible, but whenever I try to connect to it from another app it doesn't do it. It either shows "connection failed" or the app will just freeze.
rwb214
Postby rwb214 » March 12th, 2012, 9:07 pm
As my tinkering with this and gaining a greater understanding of it continues, here's where I am with it. When I connect in blueterm on my android, I get the charging info before I enter $$$ to get the command prompt, only if the roomba is plugged in and the battery is charging. That is, on the roomba 4130. The dirt dog does not give me the charging info under the same circumstances. I have changed the baud rate to 57.6 and it holds that setting when I disconnect it,confirm by entering D in the CMD prompt to get the current settings. So the baud rate should match the roomba now, but I still do not get any motion from the roomba from the RTD app. Are there any other settings I should change in Blueterm? Should I reinstall the app? Does the dirt dog have a different protocol than the 4130?
rwb214
Users browsing this forum: a4refillpad, TechGuy, vic7767 and 126 guests
