iRobot Scooba 230 Built in Test mode
Postby vic7767 » September 21st, 2011, 3:25 pm
A question about where is the SCI port on the new Scooba 230 lead to discovery of how to enter the Built in Test mode. The Scooba 230 should have the battery charged and in place and the power supply disconnected to enter into the test program. By pressing and holding both the Power and Clean buttons until the ascending and descending tones stop will place the 230 into Test 0 - LEDs test, pressing the Clean button will advance to the next test, while pressing the Pwr button will take you back to the previous test. The tests check bumper sensors, cliff sensors, liquid pump, vacuum motor, drive wheels, and other tests that I haven't figured out yet.
I suspect that the charging jack may also serve as the serial interface but until disassembly of the 230 is discovered that suspicion is not proven.
Re: iRobot Scooba 230 Built in Test mode
Postby Snupple » October 8th, 2011, 4:03 am
Have you worked out how to cancel the test? Holding Power means the power light starts flashing red rapidly, not sure what that means.. I've been pulling the battery to cancel the test mode
--- Owner of a Roomba 564, Scooba 380 & Scooba 230 :flags-australia:
Snupple
Postby vic7767 » October 8th, 2011, 10:53 am
Presently, that's how I also exit BiTs mode.
Postby chris-s » June 12th, 2012, 8:38 am
Hi Vic, did you discover something new about this test mode ?
Chris, FRANCE
Neato XV-15 since May 4, 2012
Scooba 230 since May 31, 2012
chris-s
Postby vic7767 » June 12th, 2012, 12:43 pm
No, nothing new.
Postby theirobotchannel » August 3rd, 2012, 1:23 am
hey guys since I notice you in need of the BiT for the the scooba 230, I made a video of it, hope it helps, not sure if all is complete but it gives something to work from
http://www.youtube.com/watch?v=Rhe_APesQr4&feature=plcp
theirobotchannel
Postby chris-s » August 3rd, 2012, 2:54 am
Thanks for this, very helpful to understand all steps of this test mode.
Chris, FRANCE
chris-s
Users browsing this forum: neato, TechGuy, vic7767 and 86 guests
