by pomonabill221 » June 30th, 2012, 9:28 pm
Rats! Your correct! Oh well... I just had the thought....
I noticed the bluetooth transciever that has been mentioned around here (bluesm1 I believe from sparkfun), is no longer available.
I have little to no knowledge about bluetooth, and the different boards that are around...
For just communicating between the 560 and my laptop, what should I look for in bluetooth specs.? I have seen from cheap to expensive, and other than range, don't know what the differences are.
Could I pick someones brain about this? I have been reading, but the link for the adapter says no longer available, and sparkfun has many others... just don't know what to look for.
Specifically, I would like about 30foot range, not interested in anything like a camera (yet), and just want to monitor the bots sensors while it is working, and when it is charging.
I can get the 5volts, or 3 volts with level translation from/to the bot's SCI. I will try and stuff it in a space inside the bot for permanent installation as well.
In this thread, a Toshiba stack is mentioned... is this similar to how a network stack is configured?
I will research this further on my own, but I was wondering what others have had experience with.
Thanks!
