vic7767 wrote:I don't understand why an external charging accessory for the Scooba is more expensive than the purchase of a special charger
caused me to scurry to my one specimen of a Scooba thermistor assembly and give it close scrutiny. Yep, the thermistors are parallel wired!Twobeers wrote:...BTW the thermistors in the scooba brick are approx. 5k ohms with the 2 of them in parallel. ...
In the interim, awaiting your evaluation report I decided to check out the DHgate site, and after having done so I was very much not interested in buying anything from that source. Here are a couple observations:Twobeers wrote:... ...HOWEVER, these batteries are crap. The 18650-5000mAh are only delivering 410mAh on average. The 16650-5000mAh batteries which BTW are labelled Uitrafire (that's an i not a L) are only giving me at best 2300mAh. ... 4 of the 16650's are dead after 20 minutes of use. (open circuit)...
To read the entire comment see it at this address: http://www.amazon.com/UltraFire-3000mAh ... B004LHFU62XYZZY wrote:...My only complaint is these batteries after being freshly charged cut out under a high load because of the protection circuit board which seems to be current limited to only around 2.5 Amps. For instance, when trying to drive a Ultrafire WF-502B or WF-501B flashlight with the 900 lumen Cree XML-T6 P60 LED drop-in on max power, it will only illuminate for a couple seconds and then cut off. Running it for a few minutes on medium power to partially drain the battery then allows it to run continuously on high power. The measured current draw on high power was 2.46 Amps. This suspicion was further confirmed when I cut open a cell and looked at the protection circuit card inside and found only one MOSFET driver IC, and two empty spots for additional MOSFET driver ICs. (Most other brands of 18650 batteries can sustain 5 to 7 Amps and contain two or three MOSFET drivers on the protection circuit card)...{and}...After having used these batteries for over a month now, and having gone through several charge/discharge cycles, I downgraded this review from three to one star. ... . What I found is the advertised capacity of 3000mAH for these Ultrafire 18650 batteries is a complete misrepresentation. The label on the battery says 3000mAH, however when I tested them I only observed 980mAH to 1070mAH discharge capacity for all four of the batteries I received. This discharge test was done using a Turnigy Accucell 8150 with a discharge rate of 600mAH, discharging the battery from 4.20VDC down to 3.00VDC. By comparison, I tested two inexpensive Tenergy 2600mAH 18650 batteries using the same setup and they came in at a reasonable 2460mAH and 2520mAH discharge capacity. ...
I think you will want to give that method of connection a bit more thought. I make that suggestion because Scooba's main_PCA will be subjected to higher than nominal voltage at the instant the first protective IC switches to open-circuit (in a 4S Li-ion pack) at high cell-voltage cut-off.Twobeers wrote:... I will eventually change the scooba's charge jack to one like on the roomba & rewire it directly to the battery so that when I plug into the jack it disconnects the power to the Irobot and connects directly to the battery.
Users browsing this forum: No registered users and 123 guests
