Sure, Roomba's have their own +5VREG node that is derived from its battery power; but, I'd bet money (not much, of course) that the SMPS (buck converter ckt) that down-converts battery voltage has no where near "700mA" of margin to share with any add-on peripheral. In fact, it is my guess that Roomba's buck converter's maximum current draw is way less than 0.7A. AFAIK, none of us have determined the power output capability of that buck converter.hambleturtle wrote:I'd like to connect a Raspberry Pi to a roomba 530, powering the Pi (5V 700mA) from the roomba ...
There might be on this board, somewhere, but I don't recall what or where.Are there any off the shelf solutions (or partial solutions)?
You may be able to do that by directly tapping into raw battery voltage and returning current to battery negative, and completely side stepping Roomba's elex.I'm thinking I could use a switching ... dc->dc converter ... to get the 5V power from the Roomba. ...
Gordon wrote:Don't plan on tapping into the battery voltage appearing on sockets 1 & 2 of the SCI Mini-DIN receptacle -- that power has a 0.25A (fused) limitation.
No. Sockets 1//2 have a 0.25A, resettable (polymer) fuse between them and the battery's (+) terminal on 4XXX Roombas. On 5XX/6XX Roombas one or more series diodes are between the fuse and VBAT.shining wrote:Hm, isn't pin 1,2 and 6,7 just a direct connection to the Roomba battery?Gordon wrote:Don't plan on tapping into the battery voltage appearing on sockets 1 & 2 of the SCI Mini-DIN receptacle -- that power has a 0.25A (fused) limitation.
Users browsing this forum: jin7, johnnyh, New2roomba, vic7767 and 155 guests
