by Joefly » December 6th, 2012, 12:57 pm
Hi Guys, I recently ran across a Roomba 4100 at a goodwill shop. I have made up the Din7 cable to connect to my computer using a FT232RL UART serial to USB board. When I turn on the Roomba, I see status text coming from Roomba to my PC. However, that is it! Not further txt, even if I activate the Roomba into clean or engage any sensors.
So my questions is, 1) Am I in full communication mode capable? it seems it if I can able to correctly receive info from the Roomba, unless I have the TX from PC and RX of the Roomba somehow screwed up. But basically does the fact the PC getting the initial status info from Roomba mean that they are correctly connected?
2) There are some mention the need of OSMO on the 4100, How do I confirm if I need it? It seems to me if I am getting status info that the protocol must be at least working.
Basically i am asking if 1) Do I need OSMO 2) hopefully, not, is my wiring to FT232RL correct for wiring the serial communication? 3) How do I get this working!!!
PS. I only have the RX and TX connected, Do I need to connect the DD also. and how since the serial port does not have such as pin.
Thanks guys
