Need a bit of Windows driver building so that the new Scooba 450 micro USB port can be monitored via a PC.
Here is a text dump of a driver created during the early testing of the Neato using a USB cable and a Windows PC
; Windows USB CDC Driver Vista/7 x64)
[Version]
Signature = "$Windows NT$"
Provider = %COMPANY%
DriverVer = 01/19/2011
Class = Ports
ClassGuid = {4D36E978-E325-11CE-BFC1-08002BE10318}
[Manufacturer]
%MFGNAME% = Devices,NTamd64
; Files
[DestinationDirs]
DefaultDestDir = 12
; Device driver
[DriverInstall.NTamd64]
Include = mdmcpq.inf
CopyFiles = DriverInstall.NTamd64.CopyFiles
AddReg = DriverInstall.NTamd64.AddReg
[DriverInstall.NTamd64.CopyFiles]
usbser.sys
[DriverInstall.NTamd64.Services]
AddService = usbser, 0x00000002, DriverServiceInst
[DriverInstall.NTamd64.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,usbser.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
; Services
[DriverServiceInst]
DisplayName = %SERVICE%
ServiceType = 1
StartType = 3
ErrorControl = 1
ServiceBinary = %12%\usbser.sys
LoadOrderGroup = PNP Filter
; Devices
[Devices.NTamd64]
%DESCRIPTION% = DriverInstall,USB\VID_2108&PID_780b
; Strings
[Strings]
COMPANY = "Random-Workshop"
MFGNAME = "www.random-workshop.com"
DESCRIPTION = "XV-11 Communications Port"
SERVICE = "USB RS-232 Emulation Driver"
SERVICE2 = "Low-Speed CDC Transfer Interface"
Need some clues here fellow hackers:
Need to build a Windows Driver for 450 USB
Re: Need to build a Windows Driver for 450 USB
If you are extremely lucky and the Neato uses the same usb serial port as the roomba (I kinda doubt it because I thought the Neato's USB port was built into the Atmel SOC) you could try changing the VID/PID numbers in the .inf file to match what you got from the Roomba properties in device manager.
Chances are it is one of these ICs but you may have to take it apart to find out.
http://www.ftdichip.com/FTProducts.htm
You could try starting with the driver for the roomba USB to SCI cable. Maybe Irobot incorporated that design in the Scooba.
- vic7767
- Robot Master
Big OOps Mike, it appears that when a cable is connected between the Scooba 450 micro USB to the PC USB the Windows software recognizes a device of "Other" instead of a Comm port. Snapshot below:
I think that is a non issue since with no driver the device can't be enumerated.
It could still be a comm port. But it could be anything.
- vic7767
- Robot Master
So somehow I need to build a driver and install it (associate, enumerate) with this hardware port.
Yes. I think your best bet may be to look at the inside of the scooba and find out what IC connects to the USB port. I think that is tougher with a scooba because it is sealed. But you could still try a driver from a USB to serial device.
