Roomba 870 Doesn't Respond to SCI Commands
Postby gayuha » September 22nd, 2015, 7:24 am
Hi everybody.
I try to send some commands to my Roomba using FT232RL USB to Serial converter.
I connected Tx, Rx, and RTS on the chip to Rx, Tx, and DD on the Roomba, respectively. Then I try to send commands:
128 131 to start and get into safe mode
135 to start cleaning
The robot simply does not react.
I am sure all the connections are correct. The FT232RL is set to 5v logic. I can see the LED on the chip flashing when I try to send a command, so the connection to the PC is OK.
I use Realterm on Windows 10.
Please help, I really want to make that robot move on command :)
gayuha
Re: Roomba 870 Doesn't Respond to SCI Commands
Postby vic7767 » September 22nd, 2015, 9:30 am
Place your Roomba on the charger and monitor the SCI port for the ASCII charging data that will be transmitted once per second. If you can receive data then you will be able to send data.
Postby gayuha » September 22nd, 2015, 10:03 am
I do get some data once a second while charging.
But every time I get a framing error. You can see in the lower left corner of the picture. Seems not so well to me, is it?
EDIT: OK, managed to figure this out. I simply set the baud rate incorrectly.
gayuha
Postby vic7767 » September 22nd, 2015, 10:36 am
Great! So nice when issues are discovered and resolved.
Postby soulhunter » September 12th, 2016, 2:28 pm
Have you been able to do something interesting with the 870? such as controlling it and stuff? I am on the fence about buying one and then modding it, but with was unable to find enough info about that particular model.
Thanks!
soulhunter
Postby vic7767 » September 12th, 2016, 2:48 pm
The Open Interface commands are published in a PDF document that can be downloaded from the iRobot website. The 800 models use the same commands that are published in the 500 model Roomba Open Interface document.
Users browsing this forum: boyler74, fuzzydunlop, KeldBroe, rob111gb, sondejmarek and 322 guests
