Reading Roomba sensor data
Postby El Escalador » January 5th, 2016, 2:03 pm
Having some trouble with my Roomba 535 connected to my raspberry pi. I can read the ascii startup data and send some commands, but when it comes to reading sensor data I just get garbage (trying to read using minicom). Ultimately, I need to read with C++ ... I guess it's sending binary....anyone point me towards a tutorial on 1 - making that display correctly in minicom or 2 - reading this with a C++ program (which I'm pretty new at using C++). Thanks.
El Escalador
Re: Reading Roomba sensor data
Postby vic7767 » January 5th, 2016, 6:26 pm
It's not binary data but it is HEX.
Postby mfortuna » January 5th, 2016, 8:45 pm
Here is what I did using shell commands:
viewtopic.php?f=4&t=18282&p=128523&hilit=intel+edison#p128523
Scroll up to the top.
Postby El Escalador » January 6th, 2016, 1:58 pm
Very helpful to know it's hex! So I'm able to get a visible characters now... using [142, 22] I should get millivolts back.
printf (" -> %x\n", serialGetchar (usbport))
What I get is:
-> 3b
-> 8
-> 3a
-> ec
-> 3a
-> ec
-> 3a
-> ec
Is there some way to format this so I can make sense of it? According to the Roomba OI manual, every data stream should start with 19 (I guess every stream starts with this header) but I don't see one. Should look like
[19],[n-bytes],[packet ID],[packet data(2 bytes)]
But you see that I get 8 bytes and most of those are redundant. Any clues?
El Escalador
Postby mfortuna » January 6th, 2016, 8:04 pm
Not sure why you are getting 8 bytes instead of 2. Note you are not sending the stream command which is 148.
The 3A EC looks reasonable because it comes out to about 15000mV which is 15V.
Postby mfortuna » January 7th, 2016, 9:16 am
One thing I noticed is you are sending a newline \n. You don't need to do that. I am not sure if that makes a difference.
If you look at my shell commands I put the USB serial port into raw mode, turned off echo and turned off newline to carriage return conversion. You may want to try that.
Postby El Escalador » January 8th, 2016, 9:00 am
Ahh..thanks! At first I didn't recognize the high byte/low byte separation and was confused as heck. I also tried it so many ways I forgot that I put it all in a for loop at some point so it ran 4 times.
I'm able to collect and make sense of the data now by hand...learning to write C++ that will separate and make sense of it all...that's a new challenge.
Thank you much!
El Escalador
Users browsing this forum: CleanMe, DeanR181, fuzzydunlop, johnnyh, pdjms1, TMi and 397 guests
