DIY Roomba comms cable for AU$4
Postby Kelad » September 17th, 2016, 9:01 pm
Hi All
thought this would be useful for some. You can make a comms cable for the roomba for only AU$4.
I know this has been discussed before but i though having all info in one post would be useful.
You need:
- PL2303TA USB TTL to RS232 Converter Cable - http://www.ebay.com.au/itm/191736124392 AU$2.17
- 8 pin mini din plug - http://www.altronics.com.au/p/p1098-8-p ... -din-plug/ $1.90
When you get the cable, cut off the connectors (red is not needed) and solder:
- GREEN core (TXD) --> pin 3 (RXD) on connector
- WHITE core (RXD) --> pin 4 (TXD) on connector
- BLACK core (GND) --> pin 6 (GND) on connector
See attached pictures which may help. Note the connector on roomba is female, so you need to keep that in mind when looking at back of male connector (which you solder to).
ebay cable
roomba pin out
pin out.PNG (51.03 KiB) Viewed 3394 times
To communicate with the roomba, you need some free software. Either putty http://www.chiark.greenend.org.uk/~sgta ... nload.html or Realterm. I prefer putty, but thats cause i am used to it.
Once you open putty, set baud rate, com port and select serial comms.
putty config
If you dont know the com port, open device manager.
device manager
See attachment for example. Put roomba on home base so its charging or plug cable into side port. You should then see charge log info.
charge log
:cheers:
Kelad
Re: DIY Roomba comms cable for AU$4
Postby TechGuy » September 17th, 2016, 10:22 pm
Is the device driver automatically installed when you plug in the cable to a usb port?
Postby Kelad » September 17th, 2016, 10:58 pm
Pretty sure it was automatic.
Kelad
Postby Kelad » December 4th, 2016, 7:50 pm
TechGuy wrote:Is the device driver automatically installed when you plug in the cable to a usb port?
drivers can be obtained from here:
http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41
Kelad
Return to Robotic Hacking
Users browsing this forum: dahozzman, jdong, lanchez, magura, mobzd and 250 guests
