Roomba 980 not booting
Postby StefanKrupop » June 14th, 2019, 9:13 pm
Hi all,
I bought a defective Roomba 980 off eBay and am now trying to fix it. From the outside, there is no sign of live in the unit, so no beeps or LEDs or anything, even if I directly provide power from a lab supply to the battery contacts.
However, the bootloader in the STM32 (U6) seems to be at least partially working, as I get the following UART output on J25:
Code: Select all
Normal reset
iRobot Roomba Bootloader svn version: 4042
USB PID: 2
option bytes read protect:  1
option bytes write protect: 0xfffffc00
option bytes user:          0xff
usb_activity_timeout_ms: 30000
No connection in 30 seconds, booting the app
External flash manufacturer ID is 0x9d6017
External flash unique ID is 0x5031473635370009
This repeats over and over again, it never actually "boots the app" but rather restarts. I desoldered both flash chips (U11 for the STM32 and U12 for the Wifi module) and dumped them externally. Content seems to be relatively ok (some interesting strings).
I then attached a logic analyzer to U11 and recorded what the bootloader actually does with the flash. It reads the JEDEC ID (shown as the "manufacturer ID" in the bootloader output), the unique ID and then the first 511 bytes of the flash. After that it seems to reset.
So I conclude that something might be wrong with my first bytes. One thing I already see is that my external programmer and the SPI log disagree on the 3rd byte: The programmer reads it as 0x00 (verified multiple times), while the trace shows 0xff is returned.
I'll try to fix that, but I was wondering whether somebody could help me out with a dump of their first 512 bytes of U11? For me it's all 0xff except the first 8 bytes. There I have
Code: Select all
0x01 0xff 0x00 0xff 0x00 0x00 0x01 0x00
. Bytes 5-8 could be the start address of the firmware image in the flash. But I do not know what the bootloader expects to be in Bytes 1 to 4...
Thank you very much!
Kind regards,
Stefan Krupop
StefanKrupop
Re: Roomba 980 not booting
Postby ps0001 » June 17th, 2019, 9:25 am
I don't have a 980 I can use to help you anymore, but I wanted to say I'm impressed you made it this far! Would you mind sharing the interesting strings you found in the flash chips?
ps0001
Postby StefanKrupop » June 17th, 2019, 7:07 pm
ps0001 wrote:Would you mind sharing the interesting strings you found in the flash chips?
There's lots and lots of internal function names and debug output, literally thousands.
Here are some of the more interesting:
Code: Select all
firmware version: 01.12.01#1
Camera switching to SLAM mode.
Camera switching to streaming mode.
Camera switching to QR-code mode.
Roomba 9xx Camera Test
cam-test: Found center QR code, success!
cam-test: %s: area too small: %f < %f
cam-test: got top left
cam-test: got top right
Bottom Left
cam-test: got bottom left
Bottom Right
cam-test: got bottom right
cam-test: Got all corners, success
void blahblahblah::DockTracker::addObsvHelper(unsigned int, unsigned int, bool, const Vector2*, const Vector2*)
ersp_uint32 blahblahblah::DockTracker::centerDockField()
Strategy: starting evade, shine on you crazy diamond
Strategy: evade claims success, a great day for freedom, %d
Strategy: evade failed, re-try, %d
Strategy: reached max evade failures, comfortably numb
Strategy: blocked-off, check do-able actions
Strategy: no reachable snakes, switch to pwf
Strategy: plan to go to unreachable snake
Strategy: no reachable pwfs, switch to open area
Strategy: no reachable pwf/snake, prefer going to snake
Strategy: plan to go to unreachable pwf
Strategy: inc force plan count %d
Strategy: reached max force plan, abort.
Mouse: in the beginning there was a sensor...
Mouse: sync with prod_id
Mouse: Bad product id: %d
Mouse: got correct product id: %d
Mouse: reset sensor
Evolution Robotics
LPC3250 Board
imager_ov7740: could not open device %s
Aspen firmware ver %d '%s'
A28ME8NCAI1WG2.iot.us-east-1.amazonaws.com
Received Kiss o' death from server
[%d] MQTT: FSM-%p[%d] need=%d got=%d rem=%d
/mapUpload
/mission/report
/deployment
/shadow/update/delta
/shadow/update
https://disc-%s.iot.irobotapi.com/v1/robot/discover?robot_id=%s&country_code=%s&sku=%s
Successfully sent the map to AWS S3
lwip_connect: invalid address
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
0.irobot.pool.ntp.org 1.irobot.pool.ntp.org 2.irobot.pool.ntp.org 3.irobot.pool.ntp.org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The "Received Kiss o' death from server" worried me at first, but I think that's just from the NTP client and not really killing the robot :wink:
Stefan
StefanKrupop
Postby ps0001 » June 17th, 2019, 7:54 pm
Neat, thanks!
ps0001
Users browsing this forum: BotFixer, BrettS, im1kissfan, jdong, KeldBroe, leonicholson, vic7767 and 443 guests
