The secret is: The lid is bonded (as in "glued") to the lower portion of the case! So you must crack the glue-joint via mechanical force.newmom wrote:... How do you take apart the Roomba battery case in order to get the old batteries out? ... is there a secret?
vic7767 wrote:Due to the nature of the charging system on the 500, 600, and 700 model Roombas it is vert difficult to design a LI-ion battery solution without the err 5 issue. If the battery built and the charger and 500 model Roomba are matched well then there is a successful charging process. That happened to me one time using a 535 Roomba and some 1050 mAH cell phone batteries.
TechGuy wrote:
You can still use the Li-Ion battery. But you cannot schedule your Roomba.
Users browsing this forum: jin7, Roombascoobatastic and 117 guests
