Help requested with Scheduler update/roi problems
Postby derelicte » September 19th, 2007, 8:44 am
vic7767 wrote:I'd sure like to dump the image on that OSMO, it might have some interesting contents.
we'll see what actually shows up. Is the sw to dump it in the long scratchpad thread?
derelicte
Postby vic7767 » September 19th, 2007, 6:22 pm
derelicte wrote:Is the sw to dump it in the long scratchpad thread?
I do believe that Greg may have left a download link in that long thread. Check it and see. You can also modify a cable and power up the OSMO using a 9 volt battery, plug in a RS232 connection and see what the version date is. That last request may be easier to do than dumping the OSMO into an .S record.
Postby derelicte » September 20th, 2007, 8:43 am
will do.
derelicte
Postby derelicte » September 21st, 2007, 11:30 am
I got another email from them last night re-iterating that a "purple code stick" was sent to me. It should be here sometime next week.
derelicte
Postby vic7767 » September 21st, 2007, 1:57 pm
Thanks for that info, we now know that there is possibly a third OSMO with a "Codestick Lite" banner contained within the startup program when the OSMO gets power and sends ID info to the Roomba.
Postby derelicte » September 25th, 2007, 6:58 pm
sure enough, a purple osmo module arrived today. peering through the back I see the date 050823 on the sticker.
Just for fun, I plugged it into my disco to see if it would update, which it didn't.
I'll have to bring it into work tomorrow to get the serial data out of it.
derelicte
Postby derelicte » September 26th, 2007, 3:51 pm
from the purple osmo:
contains 1 image(s):
1: roomba DG256 2005-08-11-1707
derelicte
Postby vic7767 » September 26th, 2007, 4:49 pm
Here are the IDs from the OSMOs here:
codestick-lite 2006-11-16-1623-L
1: scooba E128 2006-11-22-1616
OSMO YELLOW - For Scooba 5900
codestick-lite 2005-10-13-1459-L
1: roomba DG256 2005-10-04-1308
OSMO BLACK/SMOKE/GRAY - For 256Kb MCU Roomba
1: roomba E128 2005-08-11-1707
OSMO BLUE - For 128kb MCU Roomba
Your OSMO Purple contains the same date as my OSMO blue, except yours has the code in a 256 kb image.
Postby derelicte » September 26th, 2007, 5:01 pm
vic7767 wrote:Your OSMO Purple contains the same date as my OSMO blue, except yours has the code in a 256 kb image.
that is interesting because before I flashed my disco with the smoke osmo, it had the same firmware date but the roi wasn't enabled.
derelicte
Postby vic7767 » September 26th, 2007, 6:06 pm
Well it sounds like the ROI is working now so it is time to play. Over on the IRobot Create forum is a poster called Joe. He has a web page you can go to and download a control program he wrote for the create. It kinda works for the Roomba, try it out.
Postby derelicte » September 26th, 2007, 9:43 pm
actually I'm more interested in getting player to work, but I'm having a heck of a time getting it to do anything. I must be missing something on my linux box.
I have gotten it to work with ms robotic studio, though. However it won't run on the asus router I am planning on strapping to the top of my disco.
derelicte
Re:
Postby newmom » July 24th, 2012, 10:51 am
derelicte wrote:sure enough, a purple osmo module arrived today. peering through the back I see the date 050823 on the sticker.
Another old post, but for those of us non hackers, would someone please explain to me what this purple osmo does for a Roomba when plugged into it? I am not a hacker, I just have a number of old robots that don't work and am wondering what if anything, this old purple osmo might do for any of them if I got one?
New Mom to four irobots
newmom
Re: Re:
Postby Gordon » July 24th, 2012, 11:22 am
newmom wrote:... would someone please explain to me what this purple osmo does for a Roomba ...
I can't help you directly, but suggest that you do an Advanced-search for purple, to get about 70 results; and then search those results for osmo.
In the reduced number of hits you will quickly find a thread topic "Purple OSMO". Perhaps you will find what you ask in the associated posts.
Re: Help requested with Scheduler update/roi problems
Postby newmom » July 24th, 2012, 11:52 am
Thanks very much. I thought that is what I did to find the thread I responded to. I may have done it wrong, but I did find many, mostly referring to the hacking possibilities. I am not sure how to search within a search though, and did my seach for "purple osmo". I will try again.
I was searching mostly to understand what upgrades that might relate to wheel tachs and circle dance problems, the purple osmo might correct. I know my thread was from 2007, so I am thinking this osmo isn't likely to work with any robots newer than that, but I have a few old Discos that have wheel tach and circle dance problems still hanging around.
newmom
Postby vic7767 » July 24th, 2012, 12:03 pm
See if this link has any info you can use: viewtopic.php?f=4&t=6481
Postby Gordon » July 24th, 2012, 4:47 pm
newmom wrote:Thanks very much.
Welcome!
... I am not sure how to search within a search though, ...
Here is a reminder for you: viewtopic.php?p=107020#p107020
Users browsing this forum: No registered users and 125 guests
