piokrza wrote:I found the way how to empty the dustbin
ibarbvic wrote:Hello,
I have this very, very silent vacuum cleaner. It is fantastic!.![]()
I have a question about the charge station, It has a red button in back side, and I don´t know the utility.
Can somebody help me?.
Somebody has the english instructions?.
piokrza wrote:I learn from the manual that this button, which you describe (located on the rear side of docking station), is for "reset" the robot. It is used when your robot is fully discharged, so it is unable to dock itself. Then you have to place the robot on the dock and press just this button. It will start charging the robot automatically.
Tibor wrote:I've had this robot for a while, but I never needed to press that button. It starts charging automatically when the discharged robot is placed on the dock. (I'm not saying that the button has no function, but I didn't encounter a situation when it was needed.)
piokrza wrote:@Tibor
I'll explain to you even simpler. You have a "dock" button on your robot, remote control and on the docking station. All three are for docking "manually" (not automatically) - if you wish it (e.g. during the clening program you want to stop it and tell the robot to return to the docking station).
EDIT:
Could you check if it work as I describe?
piokrza wrote:I learn from the manual that this button, which you describe (located on the rear side of docking station), is for "reset" the robot and dock it "manually". It is used when your robot is fully discharged, so it is unable to dock itself or if you want to "tell" him to dock. Then you have to place the robot just before/or on the dock (I'm not sure) and press just this button for 3 sec. It will start docking/charging automatically.
piokrza wrote:I'll explain to you even simpler. You have a "dock" button on your robot, remote control and on the docking station. All three are for docking "manually" (not automatically) - if you wish it (e.g. during the clening program you want to stop it and tell the robot to return to the docking station).
Tibor wrote:You describe the function of the button differently in the two posts. I have tried both:
1. I made the robot run until it refused to move any more. Obviously it could not return to it's dock, so I placed the robot on the dock by hand. It started to charge automatically. No need to press the button there.
2. I started a cleaning cycle, and (with the robot in sight of the dock) I pressed that red button on the back of the dock. Nothing happened. Than I pressed the dock button on the robot itself and it returned to the dock. (I have also tried to place the robot in front of the dock and pressed the button, but nothing happened.)
So none of the above descriptions of the red button seem to be valid.
I agree that it is some kind of a reset button. I assume there are situations when the dock needs to be reset or adjusted to the robot. And this is when this button is needed. Unfortunately I could not get a decent translation from the Korean manual, so I could not read it. Anyone here speaks Korean?
Jimson wrote:Hi piokrza! I'm stalking you it seems! J/K. Congrats on your new Roboking! Have you been putting it to work? How does it fare VS the Navibot? The way the Roboking handles chair legs is very interesting.
rofl, I like how one of the attached pictures it shows the letters 'HANDLE' on the handle.
Return to All Other Robotic Appliances
Users browsing this forum: dinkydong, tjsworth, trophy, vic7767 and 88 guests
