Moderator: robotreviews
Bernd wrote:No it isn't able to go over this. I only know the Tango to be able to go over this.
Also my Roomba and some other robot vacuums i tested are not able to do so.
The Tango has a very good climbing ability, so my Tango sometimes climb into the lowest
fold of a wooden rack into my room and wants to clean there.![]()
Bernd
Ok, but I think that SR9630 is able to go over carpets: http://www.youtube.com/watch?v=Ora_u0ZicAU and low doorsteps (below 1 cm
Bernd wrote:I have the VC-RE72 too, which seems to be the same like the SR9630, so i'am able to test the climbing ability.
If you have luck, it climbs a flat carpet rug, not more.
Mostly it detects rugs as an obstacle or it is climbing badly with spinning wheels an loosing the right direction.
It's not comparable to the Tango climbing ability.
At the videolink you can see how clever the old VC-RE72 is mowing around chairlegs and thin obstacles.
I couldn't understand why they took of this necessary feature from the Tango.
If the "new" Navibot has the same firmware and mechanic like the Tango, (and i think so) this bot will
be dissapointing for some customers.
Bernd
You said in another thread: viewtopic.php?f=6&t=12782&p=76500#p76500 that the older one was better at picking up on carpet (in "Spot" mode). But how it can clean carpet if it is unable to climb on it in "Auto" mode...
Return to All Other Robotic Appliances
Users browsing this forum: angelheart, Fraggboy, logdog, neato, sageman, vic7767 and 74 guests
