Kärcher rc3000 problem
Postby lasseolsson » December 12th, 2012, 11:00 am
Strange and worrying problem on second day of new Kärcher RC3000! Received it yesterday and it runned great for 3-4 hours before I activated the parking function during the night. Now it just refuses to move or run. The green light blinks slowly if it is near the station, and it shines constantly if out of sight from the station. It does not run at all. If I try to charge it by pressing it against the station it just rolls of when I release it. Another weird thing: the two motors(?) near the brush is pretty warm, even though it has not runned since yesterday. Warm even if I turn of the unit!
Any help would be great!
Edit: I've attached an image of an object that might have fallen out of the unit. Does anyone know if it is a small part of the unit that has come loose?
lasseolsson
Re: Kärcher rc3000 problem
Postby lasseolsson » December 12th, 2012, 1:17 pm
Just found this thread: viewtopic.php?f=6&t=12143
It is obvious that the small white plastic thing is a part of the RC3000 and that it somehow has broken and come out. It surely is the reason why the unit refuses to work.
lasseolsson
Postby robocleaner » December 12th, 2012, 5:00 pm
The manual explains when/why the LED's light constantly or flash. The warm 'motors' near the brush are the batteries - they will be warm when they're fully charged. The plastic part which has fallen out of your robot is a stabiliser spring - there are two inside and they help centre the outer shell. The one in your picture is broken - your robot must have had a serious knock (or been trodden on) to break it though! It's unlikely the robot will run properly without them, but they're cheap to replace - you can order them direct from Karcher.
Spring, part no. 5.332-498.0
robocleaner
Postby lasseolsson » December 12th, 2012, 5:17 pm
robocleaner wrote:The manual explains when/why the LED's light constantly or flash. The warm 'motors' near the brush are the batteries - they will be warm when they're fully charged. The plastic part which has fallen out of your robot is a stabiliser spring - there are two inside and they help centre the outer shell. The one in your picture is broken - your robot must have had a serious knock (or been trodden on) to break it though! It's unlikely the robot will run properly without them, but they're cheap to replace - you can order them direct from Karcher.
Thanks for the reply, I've now ordered the stabiliser springs. Do you know if they are they hard to replace? I've removed the yellow top and I have located them. Do I need to remove a lot of parts/screws in order to reach them?
lasseolsson
Postby robocleaner » December 12th, 2012, 6:11 pm
Pull/lift off the rubber belly-band, take out the 4 x Torx T20 screws underneath (by the cliff-sensors), turn the robot back over, on the main board slide off the ribbon-cable connector that comes from the robot's control panel, and the top-half of the grey shell lifts off. The two stabilisers just slot in.
robocleaner
Postby a4refillpad » December 22nd, 2012, 2:26 pm
Interested to find out how you managed to order the parts. Is there a url you can share?
current bots: Samsung SR8980, Vorwerk VR-100, Roomba 770, Neato XV-25, Hauzen VC-RE70V, Evo Mint 2, Karcher RC3000, Robomow RL350 (lawnmower)
a4refillpad
Postby lasseolsson » January 17th, 2013, 5:52 am
lasseolsson
Return to All Other Robots
Users browsing this forum: neat99, TechGuy and 100 guests
