Trilobite batteries
Trilobite batteries
Postby u3b3rg33k » January 23rd, 2013, 3:00 pm
So everything I see about DIY battery packs says you can't fit two built with sub-C batteries, since they're too thick. It would appear that a few 3rd parties have started selling them:
$60ea (2200mAh) http://www.bigupbattery.com/Electrolux- ... pb1107.htm
$45ea (2200mAh) http://www.batterybay.net/Battery-for-E ... t110vx.htm
Seems to me the sub-C batteries are all around 3200-3800mAh, so that would imply that these are built with smaller cells, meaning one should be able to fit two packs. At these prices, I figure it's cheaper than me DIYing it, and if I can fit two, so much the better.
Has anyone tried random 3rd party batteries? Seems electrolux won't replace them (they've had mine for the last three months! I just called for an update and they'll get back to me).
u3b3rg33k
Re: Trilobite batteries
Postby vespaman » February 1st, 2013, 12:52 pm
About 1,5 years ago, I ordered new batteries from a german company, http://www.newtec.de (I'm in Sweden, so not too far).
Those batteries where 3400mAh, a little bit too fat, so the lid of the battery compartment looks a bit swollen. But they have been working great. They are pretty expensive though, almost double the price of the 2200.
Tomorrow morning, I'm picking up my second trilobite (used) for my basement, and I am pretty sure the batteries will need replacement, so I'm considering the 2200mAh ones for the new one.
vespaman
Postby u3b3rg33k » February 5th, 2013, 3:45 pm
What kind of runtime do you see now? I'm curious, I figure the robot may be pre-programmed to assume the batteries are of 2.2Ah capacity (as I'm told the neato's are), but if not, the run time may be improved substantially.
Assuming the former is the case, the only advantage to a higher capacity pack would be longer cycle life (less % DoD).
I'm going to try out the 2.2Ah pack as I want it to fit perfectly.
u3b3rg33k
Postby vespaman » February 13th, 2013, 4:29 pm
I don't know actually. I would guess something like 40 minutes each pack. The trilobite only changes to the next battery pack when the Voltage goes below a certain level.
The area is easily covered within one charge now, which is what is important in my house, since the room furthest away is a bit tricky to get to for the Trilobite.
I actually bought two used (good shape) ZA2 last week-end instead of one, and tonight I ordered 4 packs of 2200mAh from UK ebay (http://www.ebay.co.uk/itm/Replacement-battery-for-Elektrolux-Trilobite-ZA2-2200mAh-CE-RoHS-/300733804534?pt=UK_ConsumerElectronics_Batteries_SM&hash=item460521aff6 for them, since they will anyway service simpler areas.
According to the pictures, it is the same batteries that you have on your pictures.
vespaman
Postby newmom » April 29th, 2013, 2:43 pm
The Trilobibite battery is available now through batterybay.com
Battery for Elektrolux Trilobite, Trilobite ZA1, Trilobite ZA2
$43.79 which includes shipping. That sounds like a very good deal to me? I didn't realize there was even a place to get them. Does anyone see any reason that I shouldn't buy this? I assume this is the right battery?
New Mom to four irobots
newmom
Postby newmom » June 11th, 2013, 2:58 pm
I got my new battery pack, but I can't find any information on how or where to install them? Can someone who has a Tri clue me in?
Thanks. :oops:
newmom
Postby piokrza » June 12th, 2013, 7:34 am
Battery compartment is located here:
piokrza
Postby newmom » June 12th, 2013, 9:52 am
piokrza wrote:Battery compartment is located here:
Okay, thanks. I found a screwdriver that worked for these unique screws. With those screws, it would seem like they never wanted anyone to go in there. I think it is very strange that they don't tell how to change the battery in the manual, and I was distraught to see that there were 2 battery packs needed so my 44 dollar battery, will now cost me 88 dollars. WOW, that is a lot, but my Tri is charging now so I will see if it is possible for it to work with only one good battery now. Thanks very much for your help. :thanks:
newmom
Postby piokrza » June 12th, 2013, 10:34 am
newmom wrote:I think it is very strange that they don't tell how to change the battery in the manual,
They thought you will visit them for service every time you need to change batteries.
Yes, Trilobite works on two packs. Each one provide ca. 35 minutes of work time (according to the manual). Some users claim that it is possible to use only one battery.
piokrza
Postby Heraklen » October 1st, 2013, 7:18 am
Hi I just want to add regarding batteries that Trilobite uses the same batteries as Automower (Husqvarna) , a friend of mine works as service guy for those and told me that , so I bought batteries through him.
Heraklen
Postby newmom » October 1st, 2013, 12:03 pm
I bought from Batterybay, with no problems although I didn't realize at that time that I needed two of the incredibly spendy batteries, so mine works but not very long.
newmom
Return to All Other Robots
Users browsing this forum: meemaggie, Rar9 and 255 guests
