Electrolux Trilobite Not Charging Correctly
News and information about the Electrolux Pure i9 and the Electrolux Trilobite series Robotic Vacuums. All discussion and troubleshooting questions go here.
Postby trilobite12 » January 21st, 2017, 11:08 am
Hello
I have an Electrolux Trilobite vacuum robot that I use frequently. Recently, I have noticed that it is not charging. I have to push it hard against the base to charge. It charges fine when I do that. I have to charge it with a chair holding it in front of it to keep it charging. I noticed a direct charger port on the side. Will that help me charge it directly from a cord inside the base? I'd really like to fix the base, though.
Thanks in advance
trilobite12
Re: Electrolux Trilobite Not Charging Correctly
Postby vespaman » January 21st, 2017, 2:17 pm
First make sure that the adjustment screw on the back has support against the wall.
If it has;
If you open the charger, you will see that it is a mechanical breaker, that makes the power disappear when the pressure goes away. Sometimes they can be bent (i have seen this on one unit I bought second hand), which can be easily put right again.
Inspect that the wires leading to the connector plates are not broken, and clean the contact points.
Normally this will help. Cord chargning is possible as well, but frankly unnecessary, and more complicated than fixing the base.
vespaman
Postby trilobite12 » January 22nd, 2017, 12:12 am
Thanks. I'll try that tomorrow.
trilobite12
Postby trilobite12 » January 23rd, 2017, 4:35 pm
vespaman wrote:First make sure that the adjustment screw on the back has support against the wall.
If it has;
Thanks for your help. The wire had unscrewed from the little metal piece on the breaker.
I screwed it back and it works great.
trilobite12
Return to Electrolux Robots
Users browsing this forum: Agfadoc, instrukcije, jdong, jramer, lanchez, leonicholson, RockinRay, someoneclever, vic7767, vjxm and 379 guests
