Xiaomi MiJia Roborock Not Charging
Postby ayayaman » January 1st, 2018, 8:05 am
i get my second generation robot yesterday an in every-way i try
it go to the charging dock and say remove obstacles or cleaning
knowing that there is no obstacles and it is cleaned
Please Help
ayayaman
Re: Xiaomi MiJia Roborock Not Charging
Postby Gene2 » January 1st, 2018, 9:28 am
Xiaomi Batteries are not reliable.
1. Check voltage on the dock. It must be 20V.
If you don't have a guarantee.
1. Check all connections, like battery - PCB.
2. Remove the battery and check voltage between red and black wires. It must be 14-16V. Connect any incandescent lamp 12V, 10-20W. The test lamp must light.
3. If there is no light you can disassemble the battery and test all 18650 batteries inside it.
Gene2
Postby ayayaman » January 1st, 2018, 1:42 pm
the problem i cant play with it and open
i may return it back
i agree with you i do need to know the fault is from the the dock or the battery
ayayaman
Postby Gene2 » January 1st, 2018, 1:57 pm
Return it back then. Don't waste your time and money.
I'm pretty sure the battery is faulty.
Gene2
Postby ayayaman » January 1st, 2018, 2:08 pm
i checked the problem from the charging dock not giving output
but there is a light
ayayaman
Postby Gene2 » January 1st, 2018, 2:37 pm
You can't disassemble it without losing a warranty.
Gene2
Postby ayayaman » January 1st, 2018, 2:39 pm
i wish i can since it will be a long process to send it back
do you advice to ask the seller
ayayaman
Postby Gene2 » January 1st, 2018, 2:58 pm
Yep, ask the seller. Maybe the dock isn't giving output because can't recognize the robot itself is close to it. That means a Lidar issue.
Lidars and batteries are flaws of this product.
Gene2
Postby ayayaman » January 3rd, 2018, 2:16 am
but the robots sensor is working all well and it could even detect the dock place and try
but cant find a charging so it get confused
do you mean the lidar cause of robot battery dont emit anything for dock to charge
ayayaman
Postby Gene2 » January 3rd, 2018, 4:32 am
Try to move the robot and dock station to another place that's free of any obstacles.
Make sure the lidar is fine. If you have an IP camera with infrared LED you must see something like this (laser's dots on the walls): https://www.youtube.com/watch?v=13IqEXVoZDE
If the robot's lidar is working and robot's is cleaning, moving, navigating then possible sources of issues are (sorted by probability):
1. Malfunction battery.
2. Malfunction dock station.
3. Malfunction mainboard.
Or bad contacts (Dock, battery-MB etc).
Gene2
Postby ayayaman » January 3rd, 2018, 5:02 am
i did change place no obstacles there in both places
it is either malfunction dock or battery
regarding bad contact i did it manually several times
ayayaman
Postby Gene2 » January 3rd, 2018, 5:26 am
The problem is if you disassemble dock or battery you may lose your warranty.
At least you can consider removing warranty seal accurately like here: https://www.youtube.com/watch?v=KGcNS5g9ygg
The same about unscrewing. Don't leave tracks on screws.
One last moment. Move the robot to your dock station as close as possible or even fix it on the dock by your hand and connect any 12V 5-10W incandescent lamp to the dock's contacts (use any small magnets to fix wires on the contacts). The lamp must light. I think the lamp must be attached initially.
Gene2
Postby ayayaman » January 27th, 2018, 4:38 am
i did everything possible to do , i even contact the seller and company they stated
according to the serial number the robot is 100% working which is not the case
ayayaman
Postby Gene2 » January 31st, 2018, 5:37 pm
Assembly your own battery or find an alternative replacement for it (14.4V Li Ion Battery).
I built my own battery and don't care about it anymore.
Gene2
Postby roborock » November 29th, 2018, 4:32 pm
I managed to resolve the charging problem by replacing the battery. I contacted GearBest (the seller) and they offered me to send the vacuum cleaner back to China but that's quite expensive. They offered me a 40$ refund which I accepted. Added another 30$ and got the replacement battery. Seems to work nicely now.
Link to the battery (not original but does the work): https://www.amazon.com/gp/product/B07KM ... f=as_li_tl?
roborock
Postby Beretux » May 1st, 2019, 5:45 am
Note that Gene2's answer is not accurate as the docking station should provide 4.3V±0.5V as per the response here: http://en.miui.com/thread-3729408-1-1.html
Only when you connect robot and it starts charging, charger starts to provide 20V.
Beretux
Return to All Other Robots
Users browsing this forum: anjosva, jdong and 348 guests
