Xiaomi Roborock 2 - Error 11, Strong Magnetic Field Detected
Re: Xiaomi Roborock 2 - Error 11, Strong Magnetic Field Dete
Postby glnc222 » February 7th, 2018, 8:30 pm
These might save on buying large pieces of sheet metal. Just tape to the board, or maybe zip tie, glue.
2 in. Zinc-Plated Mending Plate (4-Pack) (also in brass finish)
https://www.homedepot.com/p/Everbilt-2-in-Zinc-Plated-Mending-Plate-4-Pack-15299/202033910
Put tape over side facing board for insulation.
Also consider a large flat washer, the kind with a small hole.
To identify the signal leads you must see which one is not affected by applying a magnet (or moving into the problem spot in the room).
Postby Hayden » February 7th, 2018, 8:51 pm
glnc222 wrote:These might save on buying large pieces of sheet metal. Just tape to the board, or maybe zip tie, glue.
Good call, thanks! I'll give this a shot and report back.
Hayden
Postby Hayden » February 8th, 2018, 1:50 am
THANK YOU ALL!
Just tested with these plates mounted over the sensors and the bot was happy as a clam. Now I just have to find a way to fit them back into the enclosure... Or otherwise make it pretty.
Hayden
Postby glnc222 » February 8th, 2018, 2:29 am
Could a ceiling fan in the floor below be causing the interference? Pretty heavy motors. Or maybe a ceiling mounted loudspeaker (some of which are shielded just for such effects, maybe not all; they have a large permanent magnet in which a coil moves the cone).
Postby Ozzyswede » January 27th, 2019, 7:06 pm
Is this the only solution to the problem?
I don’t dare taking the machine apart like that, is there no way of shielding from the outside or from inside the bottom plastic plate?
Ozzyswede
Return to All Other Robots
Users browsing this forum: ASTMedic, BCCISProf, BrettS, mobzd, ps0001, teokakav, vic7767 and 340 guests
