Xiaomi Xiaowa Smart Home Vacuum Cleaner
Postby ZTCB1 » April 4th, 2018, 4:05 am
Xiaomi Xiaowa household mopper smart vacuum cleaner home dust collector robot pet hair remover floor-cleaning detect path-plan remote app
Up to 1600Pa max suction power,three-dimensional cleaning system design, unexpected performance of the cleaning performance. Whether pet hair or corner dust, can quickly remove the dust attached to the ground or carpet.
Listed and priced HERE
Features:
* Floor Sweeping Makes chores a lot easier & faster.
* Automatically clean edge corners/places under the furniture, leaving no blind area.
* All-round high-end automatic sensor system.
* Path Planning: cleaning operation depending on the room size or how dirty the floor is.
* Automatically detect AREA RUG and strengthen suction power.
* 1600Pa surge suction. strengthen cleaning force. Electrostatic dust, hair can be effectively absorbed and removed.
* APP remote intelligent control.
* 640ml large dust box
* Go backward to the charging base to charge itself automatically when battery is low.
* Area: Apply in 80 square meters
* Finish Time: 60 minutes (depends on the actual area)
* Obstacle Pass: 1.5m-2m(max)
* Mop: Not Support
Specifications:
Brand: Xiaomi XiaoWa
Color: White
Battery: 14.4V / 2600mAh lithium battery
Wireless connection: Wi-Fi smart fast link
Rated power: 50W
Working time: 2~2.5H
Maz Suction: 1600Pa
Frequency: 50/60 Hz
Charger Voltage/Current: 100~240V 20V1.8A 50/60Hz
Product size: Approx. 35 * 35 * 9.6cm / 13.65 * 13.65 * 3.74in
Product weighs: Approx. 3.5Kg / 7.7lb
Package Size: Approx. 44.4 * 39.6 * 13.3cm / 17.1 * 15.44 * 5.18in
Package Weight: Approx. 6.5Kg / 14.3lb
Note:
- Assessories in pictures are just for a good demonstration.
- Some of the accessory parts are sold separately, for better experiences, you may need extra ones.
- Due to the light and screen setting differences, colors of item may be slightly different from the pictures.
- Please allow slight dimension difference due to different manual measurement.
What's in the box
1 x Robot Vacuum Cleaner
1 x Charging Dock
1 x Power Cable
1 x Cleaning Brush
1 x User Manual
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
ZTCB1
Re: Xiaomi Xiaowa Smart Home Vacuum Cleaner
Postby Brett » April 16th, 2018, 4:56 am
The not-so-smart smart robot?
Postby twistdh » April 16th, 2018, 5:25 am
if it doesn't have lidar is more convenient the 1st version in my opinion (if outside china)...in europe the xiaowa's price is similar to the 1st version
twistdh
Postby ZTCB1 » April 17th, 2018, 1:57 am
Yes it's a crossbreed of a Gen1 and Gen2 but without a LIDAR. The price is as low as ~ 200$ while the Gen1 had an increase to around 300$.
ZTCB1
Return to All Other Robots
Users browsing this forum: BrettS, im1kissfan, jdong, johnnyh, KeldBroe, Mekerz86, mobzd, vic7767 and 404 guests
