Xiaomi Robot vacum 2 (Mijia) Problem. Error 5
Postby 3kgt » May 18th, 2018, 4:02 pm
Just "uppgraded" or thats what i thought anyway to the Xiaomi vers 2.
Sadly already day 1 and on every cleanup it hangs upp 2-4 times and gives error 5 (Main brush stuck)! And the brush is totaly clean. Use it on low carpet.
Read that others have same problem. No fix ...
Any advise? Bought it from Aliexpress. And returning it is not an option sadly
Love robot vacums :)
Today: Xiaomi Roborock s50
Tested: Neato XV-14,15, Signature pro & Irobot 521,581, 630,650,780 + 2 Samsung modells + XV-25 + Scooba 230, Neato Botvac. Xiaomi Mi and more
3kgt
Re: Xiaomi Robot vacum 2 (Mijia) Problem. Error 5
Postby idk » May 18th, 2018, 8:48 pm
I've only heard about that error in gen 1 but not sure about #2. Have you tried running on tile/hardwood only for a bit to see if it goes off?
idk
Postby 3kgt » May 19th, 2018, 7:48 am
No . Problem is only with carpets what i have seen. I have carpet in the whole house. Still it should not behave like this.
And many complained about gen 2 in Xiaomi forums.
3kgt
Postby idk » May 19th, 2018, 1:05 pm
then i guess the motors are still the same as gen 1, I trimmed one of my bristles and it hasn't stopped on my compact carpet thus far.
idk
Postby 3kgt » May 19th, 2018, 5:40 pm
idk wrote:then i guess the motors are still the same as gen 1, I trimmed one of my bristles and it hasn't stopped on my compact carpet thus far.
Could you please put some pictures?
3kgt
Postby ivanilia » May 21st, 2018, 4:21 pm
Did you try to change settings? For instance to turn off carpet mode, or other settings. Just a thought...
Goodluck. Let us know if you found a solution. Until now Gen 1 and Gen 2 work flawlessly in our house.
ivanilia
Postby 3kgt » May 22nd, 2018, 8:33 am
ivanilia wrote:Did you try to change settings? For instance to turn off carpet mode, or other settings. Just a thought...
I did try carpet mode On. 1 time. And it worked without Eroor 5.
But Problem is that it will shorten the life of the vacum since it runs at max all the time + its acting pretty strange, most of the time even if its running on carpet it changes from Balanced (my normal mode) to Max! + running on Max is preety loud.
3kgt
Return to All Other Robots
Users browsing this forum: ASTMedic, BCCISProf, BrettS, Miles267, vic7767 and 370 guests
