Neato XV-11 Error 4005, HEX code 8055
Postby maleman876 » October 11th, 2014, 5:13 pm
When starting cleaning the vacuum spins up and down a few times, then says "My Vision was blocked. Please press OKAY (4005)"
When connecting with USB and running these commands:
TestMode On
SetLDSRotation On
GetLDSScan
AngleInDegrees,DistInMM,Intensity,ErrorCodeHEX
0,0,0,8055
1,0,0,8055
2,0,0,8055
3,0,0,8055
4,0,0,8055
... all the way to 359.
Not finding much on the code 8055.
LIDAR is rotating, The laser and sensor are clear, I assume this means I need a new LIDAR unit?
maleman876
Re: Neato XV-11 Error 4005, HEX code 8055
Postby mfortuna » October 12th, 2014, 10:35 am
Isn't there a command to read the LIDAR rotation RPM? You should check that.
Postby vic7767 » October 12th, 2014, 11:00 am
The output of the GetLDS scan should contain the rpm reading in Hz. Normally the digit seen in the output is the digit "5" which results in 5 x 60 Hz = 300 rpm.
"360 output lines of LDS Scan Angle, Distance code in MM, normalized spot intensity,
and error code. Followed by 2 status variable pairs. Example:
AngleInDegrees,DistInMM,Intensity,ErrorCodeHEX 0,221,1400,0 1,223,1396,0
2,228,1273,0 (. . .) 359,220,1421,0 ROTATION_SPEED (in Hz, Floating Point),5.00
Command:
Postby maleman876 » October 12th, 2014, 2:11 pm
At the bottom of the output it does contain:
ROTATION_SPEED,5.09
Running it a few times it varies between 4.99 (4 times) and 5.09 (once)
maleman876
Postby vic7767 » October 12th, 2014, 3:15 pm
Your Lidar appears to be within rpm specs so you might suspect other components on the Lidar unit are defective.
Postby maleman876 » October 12th, 2014, 3:22 pm
Thanks for the info.
maleman876
Users browsing this forum: BCCISProf, iangough1000, KeldBroe, sondejmarek and 159 guests
