Easy R3 Bin Upgrade
Easy R3 Bin Upgrade
Postby a1robotrepair » June 2nd, 2016, 4:21 pm
Tuck the red filter holder wings rubber seal into the bottom bin. You will have to tuck it in the first few times, after that it wifi stay formed to that position.
Re: Easy R3 Bin Upgrade
Postby a1robotrepair » June 2nd, 2016, 4:41 pm
Added some new pics
That's a pile of sneezes
Postby vic7767 » June 2nd, 2016, 5:34 pm
Postby a1robotrepair » June 2nd, 2016, 6:27 pm
Postby vic7767 » June 2nd, 2016, 7:36 pm
Postby a1robotrepair » June 2nd, 2016, 7:57 pm
Postby BR549 » July 6th, 2016, 7:25 pm
BR549
Easy R3 Bin Upgrade
Postby djos » February 7th, 2017, 5:58 pm
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Easy R3 Bin Upgrade
Postby djos » February 7th, 2017, 7:08 pm
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby bootstrap » February 9th, 2017, 2:19 am
I agree this is a great mod.
bootstrap
Postby SE_machine » March 5th, 2017, 2:41 pm
- Roomba 960
- Roomba 530
- Roomba 410 (burgundy)
- Used Scooba 5900
SE_machine
Postby djos » September 13th, 2017, 4:55 am
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Users browsing this forum: aarolar, johnnyh and 398 guests
