Easy way to add 1" to Roomba's clearance?
Postby leonicholson » June 5th, 2018, 10:12 pm
Need to prevent wedging without raising furniture.
Re: Easy way to add 1" to Roomba's clearance?
Postby Brett » June 5th, 2018, 10:32 pm
Easy! Lower the furniture!
Heh!
You used to be able to buy a "knob" or "horn" to stick on top of the halo sensor on the bumper. It was a bit less than an inch tall, was a slightly rubbery firm but flexible material, was conical from the diameter of the halo, tapering up to a rounded top. The idea is that if this touches something as it is moving it trips the bumper switch(es) turns away. Looks a bit comical, but can sort specific Roomba/furniture conflicts. Of course it may introduce a new conflict with another piece of furniture, but you can trim/tune the height...
I'm sure you could improvise something with this.
Note - I it was a 700/800 series, I'd hesitate because the plastic ring locating the halo in the bumper is very thin and does break from time to time...
Postby Brett » June 5th, 2018, 10:35 pm
Found a pic"
Available (I think?) here.
Postby mfortuna » June 6th, 2018, 7:35 am
What a cute little Rhino!
Postby harby » June 6th, 2018, 8:29 am
I just blocked access under the skirt of one couch by putting some 4x4 boards so the robot couldn't go exploring (which also works to keep a Neato's bumper-less lidar tower from wedging); one could still consider raising the furniture by a bit with some leg glides or furniture moving cups, and then it would be clean under there too.
harby
Postby leonicholson » June 6th, 2018, 8:38 am
Brett wrote:Found a pic"
Thanks! Will try this. Maybe with these, as they are cheaper and there are complaints of the things falling off and getting lost.
https://www.ebay.com/itm/Cone-Shaped-Cl ... SwVExaoI45
Users browsing this forum: BCCISProf, BrettS, im1kissfan, I'mNotARobot, KeldBroe, Metalworker, ps0001 and 396 guests
