Botvac 85 0001 Error
Postby Yannicflight » June 10th, 2018, 11:37 am
Hello Everybody,
Last week I bought a Botvac 85 with a broken battery according to the seller.
But unfortunately after replacing the battery, the Robot now shows a error 0001 on the screen saying: "Oops how embarrasing, please press Okay, 0001" I have found some topics on different places around the internet but I havent found a real conclusion to the problem yet.
Is there anyone on this forum who had the same issue and found a fix without having to change the motherboard?
Is there a way to update the firmware and maybe install vorwerk firmware on the Botvac robots? (I read that there is a difference in hardware)
Any suggestions or action points /checks to follow would be great and greatly appreciated!
Best Regards,
Yannic.
Yannicflight
Re: Botvac 85 0001 Error
Postby Medtech » July 13th, 2018, 2:12 am
If you do not know how to hold a soldering iron and are unfamiliar with the chips, then in your capabilities only replace the board as a whole. This is the simplest and most reliable way of repairing, before connecting the battery to the work board it is always worth checking the absence of a connected temperature sensor of the battery on any of the battery wires.
to all the rest of your questions the answer is only one "NO"
Medtech
Users browsing this forum: johnnyh, KeldBroe, lanchez, TechGuy, waorb and 380 guests
