Roomba 670 leaving line of dirt when I pick it up
Postby jsantana » November 28th, 2018, 10:43 am
Not sure if this is ok but when I stop the robot (click on the app button or on top of the robot button) and pick it up, it will leave a line of dust:
Even after placing it there and pressing the `spot` button, after it finishes and I pick it up, it will still leave a bit of a line of dirt
jsantana
Re: Roomba 670 leaving line of dirt when I pick it up
Postby leonicholson » November 28th, 2018, 11:05 am
I would imagine the suction stops and the last debris falls out of the brushes. Is dirt still left after "spot" cleaning if the vacuum moves on by itself and is then stopped after a bit?
Postby jsantana » November 28th, 2018, 11:08 am
leonicholson wrote:I would imagine the suction stops and the last debris falls out of the brushes. Is dirt still left after "spot" cleaning if the vacuum moves on by itself and is then stopped after a bit?
after spot cleaning, it will still leave the line of dust but less than it was before. But still leaves some.
jsantana
Postby vic7767 » November 28th, 2018, 11:38 am
Check that the filter is clear of debris, verify the brushes are spinning, and check that the dust bin motor is blowing air out of the exhaust grill.
Postby jsantana » November 28th, 2018, 12:17 pm
This is what I did. The dust there is the one on the image above. It cleaned it but leaves a bit of dust/dirt after I pick it up.
Just did, they seem to be clean and spinning. The filter is a bit dusty but I feel a lot of air coming out of the exhaust so I'm guessing it's working.
jsantana
Postby jsantana » November 28th, 2018, 12:19 pm
Anyways, I took the spinners out and the container had some dirt and dust, so I cleaned it. Hopefully that solves the issue.
jsantana
Users browsing this forum: im1kissfan, KeldBroe, lanchez, ps0001, someoneclever and 173 guests
