neato getting stuck on first object (clear my path)
Postby qwertyjjj » December 17th, 2018, 1:29 pm
Lately, my Neato has been hitting an object and immediately going to clear my path error.
I clear the path, restart and then it will it something else that it normally goes around or along and just stops with the same error.
I have cleaned the brushes and bottom sensors but have the same problem.
Any ideas what to clean or fix?
qwertyjjj
Re: neato getting stuck on first object (clear my path)
Postby vic7767 » December 17th, 2018, 1:45 pm
You can suspect that the LIDAR unit is not working correctly. Check that it is free of dust and other debris under the turret and verify the LIDAR unit is spinning. You may want to download the Neato Control program mentioned at the beginning of the Neato Robotics thread.
Users browsing this forum: DaVec, funnyfsdfsdaf-123, im1kissfan, jdong, johnnyh, leonicholson, NoJimForHome, raidencmc and 415 guests
