I7+ Disable clean base
dfp
Re: I7+ Disable clean base
dfp
around 30w charging
dfp
dfp wrote:around 30w charging
dfp
dfp
Wonderful.
dfp
Users browsing this forum: ASTMedic, BrettS, chrisko, kersian, Miles267, vic7767, vinhvu and 282 guests
