I7+ Disable clean base
dfp
Re: I7+ Disable clean base
dfp
around 30w charging
dfp
dfp wrote:around 30w charging
dfp
dfp
Wonderful.
dfp
Users browsing this forum: BrettS, fergambo, jstimson, lanchez, mfortuna, mobzd, ps0001, teokakav, vic7767 and 376 guests
