I7+ Disable clean base
dfp
Re: I7+ Disable clean base
dfp
around 30w charging
dfp
dfp wrote:around 30w charging
dfp
dfp
Wonderful.
dfp
Users browsing this forum: dfuerpo, im1kissfan, rob111gb, someoneclever, vic7767 and 260 guests
