I7+ Disable clean base
dfp
Re: I7+ Disable clean base
dfp
around 30w charging
dfp
dfp wrote:around 30w charging
dfp
dfp
Wonderful.
dfp
Users browsing this forum: dfuerpo, im1kissfan, KeldBroe, someoneclever, vic7767 and 262 guests
