I7+ Disable clean base
dfp
Re: I7+ Disable clean base
dfp
around 30w charging
dfp
dfp wrote:around 30w charging
dfp
dfp
Wonderful.
dfp
Postby jystic » July 9th, 2019, 4:47 pm
I recently purchased an s9+ from the US for use in Australia and this post was immensely useful to me. Probably the only thing on the internet which answered my questions, so thank you @dfp!
I figured I would post my experience to help give more confidence to anyone who is thinking of doing the same thing.
I am running the s9+ (with clean base) off a 1000W step down transformer, this one to be exact: https://www.wallcann.com.au/1000w-step-down-transformer/
Everything is working smoothly so far. If anything changes I will report back.
If anyone is looking for more technical details, on the bottom of the s9+ clean base it says:
50/60Hz 110-127V 12A 1.2kW
The 1.2kW made me a bit nervous, but it does seem to work without issue with the linked transformer.
jystic
Postby RTC » July 9th, 2019, 7:56 pm
jystic wrote:Everything is working smoothly so far. If anything changes I will report back.
Well, @ 110VAC and 20A the load is 1.32kW and @ 127VAC and 20A the load is 2.54kW.
Obviously if they are rating it at 1.2kW the average current draw is probably closer to <10A and the listed 20A rating must be for short surges.
But if you find you have problems with breakers in the 1kW transformer popping, you might need to go to a bigger one.
Users browsing this forum: b55er, generalielts, Ionic, lanchez, MadAEng, Rar9 and 361 guests
