My quest for a cheap LCD for Neato XV!
Re: My quest for a cheap LCD for Neato XV!
Postby flaster » April 8th, 2019, 6:34 pm
Sorry i don´t know.
Hello ,
I'm new here, I use the Google translator because I'm from Germany and find this forum at the highest level of expertise.
Now my concern. Also, I would like to use a replacement display for a Binky UI 290-0026.
I got another display ENH-DG1280128-04
also with a ST7541 chip controller.
The pinout is the same as on the motherboard.
These I have taken 1: 1. Unfortunately, I get only an empty picture.
Can someone please tell me if I can not use this display at all?
I have attached the technical data in the appendix.
Thank you :help:
ENH128128-04.pdf
(697.65 KiB) Downloaded 157 times
flaster
Postby flaster » April 9th, 2019, 4:20 am
Since the pin assignment is the same, I soldered it 1: 1 so.But unfortunately, I only get a blank screen
flaster
Postby flaster » April 9th, 2019, 6:20 am
I found out that the display does not have the i2C interface. (ST7541i) only ST7541. Is that probably the reason?
flaster
Postby mpatoulachik » May 1st, 2019, 2:51 pm
:cheers: AlainCAN :thanks:
Your fix revived the LCD in m Neato XV25!
I used a L7812ACV to provide 12V to the LCD as in this post:
http://www.robotreviews.com/chat/viewtopic.php?f=20&t=19263&start=140#p150984
I hope it will not get too warm on 24V, but I guess the power draw is minimal. And it is still easier to change than the complete LCD.
The original fix by AlainCAN for blank LCD:
http://www.robotreviews.com/chat/viewtopic.php?f=20&t=19263&start=120#p148386
I also changed the C10 capacitor (and most of the others) a few years ago to fix the dim green light of death
Long live our Neatos!
mpatoulachik
Postby poireau » July 11th, 2019, 1:25 pm
I've just made an atempt at AlainCan method to make my LCD screen go (I did it on a XV signature) . It worked, unfortunally due to my poor welding skills, i've unwelded capacitor C5 and lost it. To make it work again I need to weld a new capacitor in it's place.
My problem is I don't know the spec of this part. Does anyone knows it and can help me with the problem.
Thank you all.
poireau
Users browsing this forum: KeldBroe, Per L and 115 guests
