I've reading the archives and faq and the common advice for routine cleaning seems to be to blow canned or compressed air at the roomba.
Would not be better/faster to use a vacuum cleaner to clean the robot internals? I have a dyson with some accesories that let me access small zones without to much suction.
Thanks, again and sorry for so many questions. I am a real newbie to this roomba thing.
Ventura.
To clean roomba: canned/compressed air or better a vac?
- youbrokemytaco
- Robot Addict
For right now I'm blowing out only the filter and the bin with canned air (the type that is refillable with a portable compressor). After a month of daily use I removed all of the modules to check for debris. There was surprisingly little up inside the body of the robot. But my environment is for from extreme. I haven't needed to clean the main brushes since the second week of use. Once the 560 had it's way with the place for a while it now keeps it under control!
- youbrokemytaco
- Robot Addict
Exactly what I use...
I use the crevice tool on my Dyson when I'm just sucking under the bumper and around the wheels etc, and then when I do a more thorough clean I use the soft brush tool to brush off dust so it can be sucked up. My Sage looked completely grey inside when I opened it, after 30 mins of careful brushing and vacuuming it looks sparkly new
In general air compressors can produce a very high velocity air stream that pushes out more dust. Vacuum pull air in which accelerates only at the narrow entry point. Therefore compressed air can disturb far more dust. On my old generation roombas there are plenty of openings so that air will always escape carrying with it dirt. Even wheel hubs work well as air must escape some place else.
In general dirt doesn't get stuck or pushed further into a bot because dust and hair is light so keeps being carried by air flow which eventually escapes out.
The only problem is that it is best done outside. I do it in my garage and promptly run away to let all the dust settle down and avoid inhaling it. Afterwards I just use a broom and sweep it out as part of regular garage cleaning.
Good to find someone that thinks the same way as I do.youbrokemytaco wrote:I'd rather pull the dust out the way it went in than use compressed air and shove it further into the machine. Plus you don't get dust in the air, it's all contained.
I've just bought one of these:
http://cgi.ebay.co.uk/Vacuum-cleaner-ad ... dZViewItem
Wasn't sure if it was just a gimmick, but thought I'd try it anyway - I dont' grudge my Roombas anything
Arrived today, so far very impressed - good for getting into the bits that the Dyson Crevice tool can only dream of! Also, very good for cleaning the filter,
