Howardpm wrote:The charging base is also a lot smaller.
Howardpm wrote:Also the packaging is a lot worse then before, they used to pad it with styrophone, not its a paper like material.
There is no question, the debris bin has been largely re-worked! This "Aero-Vac Bin" represents the most significant bin revision since the 5XX series introduced its more powerful, more efficient suction-fan!Howardpm wrote:...Looks like the dirt tray has been resigned, they now call it the Aero-Vac Bin,...
The way to view that portion of the revision is, the 5XX fan has always been in the large-debris compartment, but the suction entrance to the fan has always had a separate plenum which draws outside air up through a pair of close-spaced squeegee lips, thus keeping the fine particle movement totally separate from the coarser debris being whisked up via the bristle brush....looks like the fan to suck in dust has actually been moved into the dust bin...
The debris accrual volume of the Aero-Vac Bin has is probably larger than the predecessor 5XX bins (those having fans), because deletion of the separate suction plenum, and its associate separating wall, ends up donating additional space to the debris chamber....and is now surrounded by a rounder filter which seems to take up a lot of space. ...
I see your point about that, and it reminds me of a question or two. I'm inserting a composite of your two bin images, for reference:I don't like this design I'm touching more dust and dirt then I did with all previous ones, you have to put your hands into the dust bin to pull the filter out now to tap clean.
That is a good point! I wonder if iRobot actually performed some verification tests before committing the Aero-Vac Bin to production(?). I can visualize either a loss in Roomba's ability to collect fine particles just as easily as I can see it may be a wash. No one has stated (in your thread) the Aero-Vac Bin has no squeegee lips, but I see none in the pix, and I see no way for Roomba to use them now that air-flow has been redirected, so I assert they are no longer present.Major step backwards, I can't tell if its pulling up more dirt/dust or not.
) and (I think) more customers are interested in them. The price is comparable with Roomba 500 series. So Irobot must doing something to attract customers - they put sucking fan after main brush. It probably changed the way to clean 180 degrees
piokrza wrote:http://www.youtube.com/watch?v=LSoSXic_nC8
