vic7767 wrote:It may be time to measure the battery voltage after a full charge and then if the voltage is between 16 and 17 volts perform a load test on it. How old is this battery ?
Luciano, please state whether you elect to not use a Home Base, or not use it because the 520 has no Home Base and no HB's electrical contacts on the robot.bolero1000 wrote:... I simply unplugged the roomba from the charger (I don't use the base), ...
Gordon wrote:Luciano, please state whether you elect to not use a Home Base, or not use it because the 520 has no Home Base and no HB's electrical contacts on the robot.
Gordon wrote:BTW, I'm glad to see your 520 has corrected itself, but be sure to say something if it reverts to its error state.
Thanks for that. Perhaps the "520" is the USA-530 bundled with a 240VAC-mains capable charging-PSU!bolero1000 wrote:Hi Gordon,I simply don't use the base, but I've it & the 520 (at least the European one) have the contacts.Gordon wrote:Luciano, please state whether you elect to not use a Home Base, or not use it because the 520 has no Home Base and no HB's electrical contacts on the robot.
No, it is suffering a failure. After reading your OP, I gave this a lot of thought, and did some tracing of the charging current path on a loose 510-PWB, but could not get enough of the circuit diagram in front of me to be certain about my thoughts.I found a way to "replicate" it (perhaps...), if I unplug the charger during the charging (flashing orange), the roomba continue to flash orange also unplugged for 30sec-1min .. perhaps it's done on purpouse (stays in charge "control" mode) to handle possible power problems (spikes or other) ??Gordon wrote:BTW, I'm glad to see your 520 has corrected itself, but be sure to say something if it reverts to its error state.
I can only parrot what the manual says, and it is this:... ... someone could clarify me, for the selftest in MANUAL-ADVANCE MODE, how do you understand if a test passed or not ?? I thought it was when Clean become green but not so sure now ...
Service Manual wrote:MANUAL-ADVANCE MODE
This is designed to be used for debugging particular sensors or actuators. In this mode, the robot
DOES NOT decide PASS/FAIL for each test number.
Gordon wrote:No, it is suffering a failure.bolero1000 wrote:I found a way to "replicate" it (perhaps...), if I unplug the charger during the charging (flashing orange), the roomba continue to flash orange also unplugged for 30sec-1min .. perhaps it's done on purpouse (stays in charge "control" mode) to handle possible power problems (spikes or other) ??
Gordon wrote:As a test, you might try setting up the Home Base for charging and let the 520 charge from that source. See how well that works.
vic7767 wrote:The only way to determine a Pass/Fail in manual mode is to monitor the test results via the SCI port.
Yes, when the documentation mentions a visual way to determine Pass/Fail then use the results that are mentioned. What I attempted to explain is that on the tests that have no Pass/Fail indicator you could use the output of the test in ASCII via the SCI port.bolero1000 wrote:Just to make an example, the simple test 2 for bumpers, Tester Action "Press and release left bumper. Press and release right bumper.", if the Spot & Dock LED goes on (& the Clean goes green) could I says that test's passed or not ?
NO. I did no active testing, only analysis by examining a spare circuit board.bolero1000 wrote:...Do you mean that you tried to unplug the charger while roomba is charging (flashing orange) & it not flashing orange (unplugged, for 30sec-1min) ??
Gordon wrote:NO. I did no active testing, only analysis by examining a spare circuit board.
Gordon wrote: If so, the main board has a charging system fault, and it is not likely that you will be able to fix it -- other than by replacing the (alleged) failed board.
I ran my 535 on carpet for about half an hour, and then set it to direct charging. After waiting about 10 minutes, I unplugged the dc power and noticed that the Clean-button LEDs went dark within a second or two, and stayed dark until I resumed charging. About 30 minutes later, I repeated the charging interrupt, and the LEDs again went dark very quickly.bolero1000 wrote:...It'll be interesting, at least for me, if someone could try on his 5xx to unplug while's charging & confirm if the Clean goes off (or continue to flash orange) ...
Gordon wrote:I ran my 535 on carpet for about half an hour, and then set it to direct charging. After waiting about 10 minutes, I unplugged the dc power and noticed that the Clean-button LEDs went dark within a second or two, and stayed dark until I resumed charging. About 30 minutes later, I repeated the charging interrupt, and the LEDs again went dark very quickly.bolero1000 wrote:...It'll be interesting, at least for me, if someone could try on his 5xx to unplug while's charging & confirm if the Clean goes off (or continue to flash orange) ...
Basically the same as bolero1000 experienced.rangatanga wrote:One of my Roombas 560 starts to behave very strange - ... .
None have been posted, as yet. I have been studying the fault as time permits. I think the self-powering occurs as I described in the referent thread, but have no clue how the circuit may be designed to overcome such a built in fault, or why all 500-Roomba owners don't experience the problem.Any suggestion where to find the culprit?
I can suggest measurements that will confirm how battery power flows in a reverse direction through the charging FETs to then power the robot, but resulting data will only confirm that flow, rather than lead to a correction.What voltages to measure to identify the malfunctionig part?
Michal, I think that may become useful data as we learn more about this problem, but can't see what to make of it at this time.another rekmark - when MB is connected to regulated PS it works within range 12-14 Volts. When the voltage exceeds roughly 14,5 Volts, the charging light starts to blink. Thats why it blinks with battery connected since charged battery voltage is more then 15 Volts.
Users browsing this forum: 911medic, BCCISProf, FlyingPolarBear, im1kissfan, KeldBroe, leonicholson, Miles267, someoneclever, sshephard, vic7767 and 389 guests
