Charging Error 3
Charging Error 3
Postby Bobtb » March 1st, 2011, 4:59 am
Ok, I have a 560 series mainboard that keeps giving me charging error 3. Battery is not the problem as it had been tested with a working one. It is confirm to be the mainboard as the same battery charges and work fine on the other 550.
I bought another used 560 which also had a charging error 7 every 4 hrs into charging and also verified to be the mainboard problem. Any advice with the charging error 3 & 7? Which is the charging FETs that Gordon mention on the sticky post for fixing the false charging systom?
TIA
Bobtb
Re: Charging Error 3
Postby iMayne » March 1st, 2011, 12:14 pm
Hi.
You will need to reply to that topic and your answer maybe answered there; hopefully.
UK Business Coming Soon
iMayne
Postby TechGuy » March 1st, 2011, 12:47 pm
Bobtb wrote:Ok, I have a 560 series mainboard that keeps giving me charging error 3. Battery is not the problem as it had been tested with a working one. It is confirm to be the mainboard as the same battery charges and work fine on the other 550.
TIA
From the Service Manual, Charging Error 7
Battery not Cooling. This occurs when the battery doesn’t cool within 4 hours. Most likely the battery thermistor is shorted.
If your battery works on your 550, the thermistor on your battery is working and your battery is not the problem. Bend the small battery contacts up slightly in the battery compartment. If this does not fix the Err7 problem, the component reading the thermistor value on mainboard may be the problem.
From the Service Manual, Charging Error 3
Charging FET Failed. The occurs when the FET test fails at the beginning of the charge cycle.
The battery contacts may not have good contact with the battery. Bend the large contacts and try charging again. If you have a SCI cable, get the charging logs.
Postby Gordon » March 1st, 2011, 12:57 pm
iMayne wrote:...You will need to reply to that topic and your answer maybe answered there; hopefully.
No. Bobtb did such a post and I had to tell him the error(s) were off topic (you should have seen that exchange); so he has correctly started a new thread.
TechGuy has given him good information & guidance.
Gordon
Postby Gordon » March 1st, 2011, 1:09 pm
Bobtb wrote:... Any advice with the charging error 3 & 7? Which is the charging FETs that Gordon mention on the sticky post for fixing the false charging systom?...
I can't see how you arrived at the conclusion that charging FETs are related to the false charging issue! Can you point to where I said something like that?
As far as I know, the false charging fault is not accompanied by any error message. I can see that it should report Err5 (charging current too low for too long), but not Err3 or Err7.
Gordon
Postby bhylak » March 1st, 2011, 1:43 pm
Yes, just in case the op doesn't understand, the false charging problem is where the Roomba continues to charge itself even after it is unplugged/undocked. The Roomba really thinks it is still charging, and is charging itself from itself, so no error is reported.
Sorry if anyone thinks this is a repeat of what Gordon said, I tried to put it in simpler terms.
Ben
Homemade Telepresence Robot:
bhylak
Postby Gordon » March 1st, 2011, 2:03 pm
bhylak wrote:Yes, just in case the op doesn't understand, the false charging problem is where the Roomba continues to charge itself even after it is unplugged/undocked. The Roomba really thinks it is still charging, and is charging itself from itself, so no error is reported. ...
Very good, bhylak. The only edit I can suggest is to insert the word apparently two places, to make your sentences read this way: ...the false charging problem is where the Roomba continues to apparently charge itself even after it is unplugged/undocked. The Roomba really thinks it is still charging, and is apparently charging itself from itself, so no error is reported.
Gordon
Postby bhylak » March 1st, 2011, 4:31 pm
Right, thanks.
Ben
bhylak
Postby Bobtb » March 2nd, 2011, 5:37 am
TechGuy wrote:From the Service Manual, Charging Error 7
Yes, it gives me a charging error 7 every 4 hrs and the battery is confirmed to be fine. The contacts had already been tried. Which is the component reading the value?
As for charging FET, I know the manual says test fail that's why I was asking Gordon which component is the FET. It might not be it but since the board is useless now, I just wanna try my luck. I have a cable (the one on irobot site with a USB end, I hope this is the one you're refering to) somewhere but I do not know where is it now and had never use it before.
Bobtb
Postby Bobtb » March 2nd, 2011, 5:42 am
It does report Err 3 and even a lady anouncing "Charging Error 3". The Err 7 is another board, it's 2 different issue.
You did not say that problem lies with the FET but I was just hoping to try my luck on it since the board is sitting there collecting dust as I chance upon your post mentioning something about FETs. There is no harm trying as I could not find any post with solution for Err 3 or did I just miss it?
Bobtb
Postby Bobtb » March 2nd, 2011, 5:47 am
Thanks for the 2 cents, I know what he is refering to and I now have 102 cents.
Bobtb
Postby Gordon » March 2nd, 2011, 1:30 pm
Bobtb wrote:...It does report Err 3 and even a lady anouncing "Charging Error 3". The Err 7 is another board, it's 2 different issue.
IMO, you should have kept these cases (err3 vs err7) separate, by appending to existing topical threads, or starting new ones, as necessary. In this reply I will limit my response to err3.
I don't recall whether err3 has been treated directly, and I did not search for it, but you might try searching again for err3, w/o a space character.
I think you may be helped by knowing more about how the Charging-FETs Test functions. With better understanding, you may be able to craft more useful search search strings and uncover applicable work.
What I say next should be prefixed with weasel words such as "as far as I know", or "our present understanding is...".
The Charging-FETs Test is performed only in the half minute following connection of charging power to Roomba.
Two power MOSFETs are connected in series to provide a means for the robot to always be able to halt charging if one of the FETs should become always-conductive (by transforming into an always closed switch (these FETs are either ON/CLOSED or OFF/OPEN; they are not operated as partially ON devices)). Their board markers are Q17 & Q18.
IOW, two in series provide a safety function. The purpose of the FETs check is to verify that each FET is controllable (i.e., when its gate voltage is HI, its channel is OPEN (high resistance), and when gate voltage is LO, the channel conducts current).
As charging voltage reaches Q17 & Q18 it normally can't pass through the FETs because they are biased OFF by battery voltage applied to their gates; and at that instant the presence of charging voltage is detected by the MCU causing it to switch from standby mode to charging mode. Charging voltage takes over the biasing job to hold FETs OFF.
The first thing done by the charging routine is to call its FETs check routine into service; and the first thing that must be known is whether charging current happens to be flowing already (which would show that both FETs are conducting when they should not). That would be Test-1; pass IF no current / fail IF current is high.
Tests two & three, individually, sequentially pull Q17 (or Q18) gate LO, then check for current flowing (through both, since in series). IF current is zero, pass, else IF current greater than 0 amps, fail. Failure shows that one FET is permanently shorted, its gate voltage has no effect, which means charging current control is via only one FET, and if it too were to become uncontrollable, the robot would be unable to halt the charging process. The MCU executes the Err3 announcement.
The final test, Test-4, pulls both FETs gates LO, turning ON both FETs, and the MCU expects to see high-rate charging current (1.3A) flowing through the battery. Pass, IF current is HI, fail IF current is below some unknown threshold. Failure here produces the Err3 announcement, but the actual fault may have nothing to do with the FETs -- it could be a PSU fault, or resistive contact along the charging path, or even the battery's cells.
If all tests pass, the charging controller removes gate-drives (gates go HI) to switch FETs OFF, and then steps up (using PWM control, rather than analog control to increase current to max.) charging current over a short interval to the high-rate level, and the battery is formally under charge.
All sampling of charging current is done by measuring voltage developed across the system's master current shunt resistance (0.05 ohms of R235//R257).
Q17 & Q18 are located in the forward, left quadrant of the mobo, as shown here:
Before you fool around with testing Q17 & Q18, it would be prudent for you to read a method that discusses hand testing the charging FETs on a 4XXX-Roomba's mobo. That same process can be applied to the 5XX-Roomba mobo, but with one difference: 4XXX=Roomba's FET-gates have a single driver xstr, whereas 5XX-Roomba uses two drivers.
I will be very surprised if your 5XX-Roomba has suffered failed charging FETs -- there are several design features that, when combined, make failure of Q17 & Q18 much less likely than we saw for the 4XXX series.
Gordon
Postby TechGuy » March 2nd, 2011, 4:20 pm
Bobtb wrote:...I have a cable (the one on irobot site with a USB end...
I don't know what cable that iRobot sells because I made my own cable. Someone, who knows what iRobot sells, please help.
One side of the cable should have a 7-pin DIN male connector. The other side can be a USB connector or a RS-232 connector.
Here is an article on "Troubleshooting with Roomba SCI Cable". After you have determined that the charging circuit is no good, you need to replace the Q17/Q18 discussed in Gordon's post.
Postby vic7767 » March 2nd, 2011, 4:59 pm
iRobot sells two different RS232 cables for connecting the Create robot to a PC. One cable has a DB-9 pin connector on one end and the other end has the 7 pin mini din. There is also a USB version of the same cable. Both cables have an RS232 to TTL interface converter built in.
Postby bhylak » March 2nd, 2011, 6:38 pm
Right, so unless your computer has a serial port you have to get the USB version.
Ben
bhylak
Postby jackie7380 » November 4th, 2013, 2:23 am
I have iRobot 530 has error 3 problems and I fix the problems today. I switch 3 battery 3 charger all the same.
The charging FET is ZXMP4A16 but I use two BP250 ( I fix iRobot 4110 won't charge it use BP250) replaced it but still the same problems error 3 I used magnifi glass took a look the battery 4 connector to contact with battery from buttom two big connector has green rusty around it , It must the battery leaking before, also inside beaide the Q18 about 8 resister both side has geen rusty same as battery connector, I used heat gun and soldering paste resoldering every rusty resister both side also the battery connector inside now is working no error 3 hope this can help someone has same problems as me. ZXMP4A16 and BP250 are same function FET fix 4100 only need one FET.
jackie7380
Postby nprb » September 18th, 2014, 9:52 pm
I had a 570 with charging error 3. The battery terminals showed signs of corrosion where they were soldered to the board. I tore the unit down to get to the main board. I also found corrosion on the top side of the board, mainly on those between the battery terminals, VBAT and GND. C112, R252, R253, R254, R255, C113, Q19, C125, R278, R279, and some at IC U8. Cleaned in with a toothbrush and 'Safety Wash Cleaner Degreaser', which is mainly denatured alcohol (ethanol). Warmed the board up to dry off all the alcohol and reassembled the robot. No more charging error.
nprb
Postby Gordon » September 18th, 2014, 11:36 pm
nprb wrote:I had a 570 with charging error 3. The battery terminals showed signs of corrosion where they were soldered to the board. ... I also found corrosion on ... C112, R252, R253, R254, R255, C113, Q19, C125, R278, R279, and some at IC U8. Cleaned in with a toothbrush and 'Safety Wash Cleaner Degreaser', ... No more charging error.
Grand work, nprb! I would say that cleaning around (quad op-amp, LM324) U8 is the work that was necessary.
U8 (and its peripheral passives) provides to Roomba-R3 the service of signal conditioning low level analog signals that are sent on to the MCU and turn in to these critical measurement data: a) total system current, b) battery voltage, and c) battery cells' temperature. Wrong values of system current could have caused your err3 issue.
If interested in U8's workings, I left a post about them here, in y2013: http://www.robotreviews.com/chat/viewtopic.php?p=117112#p117112
Gordon
Postby mark206000 » September 24th, 2014, 6:15 am
Sorry to hijack your thread :oops: I'll make a new one if need be !
I'm getting an Error 3 also.
I've just got my roomba 530 from storage after about 3 years sitting in it's box with battery still inside. I ordered a new battery, not an original part a 4500mah 'upgrade'.
When the battery arrived it was charged so I set the roomba off and let it do its thing. It docked itself after a while and had a battery error 2. I read elsewhere on the forum to let it discharge then try again, this did work twice. Now all I get is Error 3.
I've opened it up and took pictures of the same parts as above Q17&18 and U8, all look fine to me ref corrosion.
What should be my next course of action, can I test any of these in situ ?
Thanks !
Mark
mark206000
Postby Gordon » September 24th, 2014, 1:34 pm
mark206000 wrote:...I'm getting an Error 3 also. ... roomba 530 from storage after about 3 years sitting in it's box with battery still inside. ...a new battery,... arrived ... charged so I set the roomba off and let it do its thing. It docked itself after a while and had a battery error 2. ... Now all I get is Error 3. ...
I've opened it up and took pictures of the same parts as above Q17&18 and U8,...
What should be my next course of action, can I test any of these in situ ?...
Yes.
Nice pix.
You might try cleaning--as nprb did--the U8 region.
You ought to be able to verify U17/U18 gating to be correct while running the BiT that exercises trickle or high-rate charging currents.
Your reported errors seem to point more to U8 and peripheral components, than to the charging FETs.
Else:
Get a grasp on what err2 & err3 mean by reading this post: viewtopic.php?p=120477#p120477
Read the link I provided in an earlier post, to the OP (Bobtb), until you grasp what I did to obtain the U8 functional data therein.
Perform similar measurements on your 530's U8 to verify all sections of U8 are conditioning input data in reasonable conformance to my tabled data.
Gordon
Next
Users browsing this forum: dboston55, im1kissfan, johnnyh, KeldBroe, leonicholson, NoJimForHome, vic7767, wassct and 428 guests
