There is no evidence that this is a mobo fault; however, I can point to a faulty Roomba operator as being a major threat to the hardware!Linux.Is.Skynet wrote:...before I charged it the last time I drained the battery running in diagnostic mode (Running brushes, vacuum and drive wheels) for two hours. Maybe there's something screwy with it's mobo. ...
...and, specifically the phrase "operating without the normal safety features" is the critical portion. I will grant you that the warning's wording stresses operator safety, and mechanisms' safety (including their electronic drivers' safety), and says nothing about battery safety. So that warning is weak in that it is not idiot proof.Test-Proc wrote:...a Roomba in Diagnostics Mode is operating without the normal safety features that stop the motors when Disco is either lifted off the floor, or a stout article becomes wedged in a running mechanism. Not only must due care be exercised when using hands to reorient Roomba while its motors are powered, but if anything halts a running motor, for more than a second or two, there is great probability that the motor or its related electro-mechanical parts could be ruined! ...
This is a great example of the danger to the hardware while running tests on a machine that has its normal protections suppressed!Linux.Is.Skynet wrote:Actually this is not an example of the dangers of using the diagnostic tests.
I have not lost track of that. Did you notice my recommendation about battery testing?All of the errors I noted happened well before I ran any of the diagnostics.
You must put that Home Base out of sight until we get the robot, PSU and battery working together. Don't even think about the HB until that happens.The home base never worked before I received the robot,... and it still doesn't work...
We had been running the built-in tests for a couple years before iRobot changed the warranty rules without warning. We were mystified by the Company's action. Eventually I began to see how mechanisms, drive wheels in particular, could suffer damage by allowing the robot to wander around on the floor bumping willy-nilly into objects while having no capability to do normal Clean-mode evasions. Your act of running for hours in a test-mode was the first ever reported, and allowing the robot to fully discharge its battery is an excellent example of electrical abuse of the diagnostic warning.... I see little point to your post.
I am well aware of the quantity of those problems, and their nature. They are so much the same, but the owners come in with a mind set, thinking their battery just can't be the problem, after all it measures 15-volts! I've long wanted to be able to write a general procedure that owners like you could use to get from a non-working system to a working system, but the weak point in that process is always "what level of understanding does the user have about electricity, and how well equipped is s/he to do necessary tests". If people are ill equipped, one approach is to substitute known good sections into the system to see what fixes the problem. Another approach is to ship the system to a repair facility, where all will be taken care of for a fee.My roomba is doing the same thing it did before I ran diagnostics. I like the Roomba but I've heard alot of complaints about battery failure and mobo failure in less than a year of ownership of the second generation models. So ... read through the other forums and maybe you'd see that there are many other people with the same problem as me.
Users browsing this forum: neat99 and 93 guests
