Roomba 561 problem
Roomba 561 problem
Postby PHOENIX2000 » February 23rd, 2011, 6:09 am
Hello.
I have Roomba 561 about 4 months old.
Recently became a permanent jump (flip), the sound of the engine somehow changed and I think roomba began to go a little slower, as though something in his way. Every 3-5 minutes it stops with error 2 - clean brushes.
All that was possible - clean. I removed the bottom cover and then pull out the block in which the brushes are mounted - one in which the motor is worth. There is relatively clean.
Here's the video: [video]http://www.youtube.com/watch?v=mvZe5Mdz7Ok[/video]
If I run Roomba without a brushes, then flicks (jumped) does not vanish, ie it is clearly not in the brush. Maybe somewhere else dirt could hide? that suggest?
Thanks in advance.
PS My English is very bad, sorry :(
PHOENIX2000
Re: Roomba 561 problem
Postby bhylak » February 23rd, 2011, 7:07 am
Don't worry just search the forums for CHM. What happens is hair gets lodged in there...
http://www.vic7767.com/modded-chms-to-f ... hes-error/
You can just open the CHM and take out the hair, but it will come back without the bearing mod...
Ben
Homemade Telepresence Robot:
bhylak
Postby iMayne » February 23rd, 2011, 9:11 am
Also make sure that the height adjustment cable i not broken. That sometimes cause the clunking sound.
UK Business Coming Soon
iMayne
Postby PHOENIX2000 » February 23rd, 2011, 3:27 pm
bhylak wrote:Don't worry just search the forums for CHM. What happens is hair gets lodged in there...
Thank You very much! You are absolutely right:
PHOENIX2000
Postby iMayne » February 23rd, 2011, 3:32 pm
WOW! No mod for you! You need a new modded deck or a complete modded CHM! Pay Vic a visit :)
iMayne
Postby PHOENIX2000 » February 23rd, 2011, 4:11 pm
No, I cleaned it and now Roomba works fine!
But i see than there is some small damages on green plastic.
PHOENIX2000
Postby iMayne » February 23rd, 2011, 4:14 pm
Problems will develop sooner or later. Hope you've added lithium grease!
iMayne
Postby PHOENIX2000 » February 23rd, 2011, 4:17 pm
Thank you very much!
I'll do it now.
PHOENIX2000
Postby bhylak » February 23rd, 2011, 4:22 pm
No problem. Definitely think about the bearing mod. What happens is it builds up and it can start to heat up the motors damaging those and possibly even messing up those gears. So unless you want to do this regularly, get the mod.
Ben
bhylak
Postby poconogal » February 23rd, 2011, 8:06 pm
Since your Roomba is only about 4 mos. old, it should be under warranty. Next time that happens, if you call iRobot and tell them what message you were getting, they will send you a new CHM. Don't tell them you opened the CHM up. I've got a little collection of CHMs that I received from iRobot while my 581 was under warranty. One is still brand new in the box, which I've been saving to have a mod done. The others I open and clean every few months.
Connie
The robot did it...
poconogal
Users browsing this forum: 911medic, BCCISProf, fuzzydunlop, jdong, jtheruler791, Metalworker, Miles267, off-road-biker, RockinRay, vic7767 and 334 guests
