If I were doing the work on my own PSU, I would leave the T3.15A untouched. See this post (a post in one of your referent threads): viewtopic.php?p=46555#p46555eddise wrote: modding of its Power Supply Unit, PSU (17062) to work on 220v/240v. I seems to be almost ready but need to confirm on a FUSE ! ...
? 3. A Fuse F1, replace to 1.6A 250V (from T3.15A 125v)
Yes, and thank you for a great set of PSU pix.eddise wrote:Hi Gordon, Thanks for the respond, appreciate that. Hopefully you could further advice few of my doubts.
As I recall, the "391" equates to an onset voltage of 390V, and if so, you want to compare the peak mains voltage to 390V, making sure that Vpk is less than Vonset. Vpk = SQroot2 * 240V = 1.41 * 240 = 339V, so you have 390 - 339 = 51V of margin voltage to accommodate brief surges and voltage spikes which normally occur on the mains....- (BTW, Is my varistor fine 391KD14 ok? )?-
I have no personal experience with it, but, as you read, red_sword_fish has confirmed that relationship. But, some members have reported no fault with their PSU by not changing D11.And, there is another Diode, D11 to replace -> target is 1N4007 (any in the 1N4001 to 1N4007 family). Does this replacing this diode has anything to do with a regulator 78L05?
Actually it does use the 78L05. Look at this blow-up from one of your pix:I can't see a board marker (Uxx) for that regulator, but its in the same relative position to C11 & C18 as on r_s_f's PCA. Notice the marked dates on your PCB and on r_s_f's; his is three years older, and some components have been shifted (careful inspection would be needed to detect whether some have been deleted and or replaced by new devices -- slight circuit changes may have been done) over those years. Upgrading D11 (to 1N400x) will not harm anything, and right now the work can easily be done.I have query on this diode is because, Having read viewtopic.php?p=67069#p67069 ,saw its pics. I discovered , my PSU does not use the 78L05 regulator. ...
Answer:bcarpenter wrote:The Roomba's power supply is just an AC to DC transformer. What's wrong with wandering into Dick Smith & buying a transformer with the same output voltage, power & plug size?
Since you have ordered parts from (USA) Mouser, I presume you live in the US, and have 120VAC outlets in your house.550bot wrote:...http://www.mouser.com/Search/ProductDet ... V175LA10AP
That is: 120VAC+/-5%. When mains voltage is highest (126VAC, rms), it impresses root2*126V = 1.414*126V = 178 peak-volts (for a couple milliseconds each half cycle) across the varistor, so, depending on the tolerance of the varistor's 175-V_BDonset parameter, the varistor may, or may not start to conduct shunt current.wiki-org wrote:{USA domestic mains are} Standardized at 120 V. Electricity suppliers aim to keep most customers supplied between 114 and 126 V most of the time. http://en.wikipedia.org/wiki/Mains_elec ... by_country
Users browsing this forum: TechGuy and 128 guests
