neato HEPA filter DIY mod v1
Re: neato HEPA filter DIY mod v1
Postby djos » August 28th, 2011, 7:55 pm
Mtbook, nice work but what do you mean by dryer sheet?
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby mtbook » August 28th, 2011, 8:11 pm
Like the Bounce fabric softener sheets you throw in the dryer - they normally come in boxes of 25-100
Some people use them as makeshift filters for computer fans too
mtbook
Postby fetish » August 28th, 2011, 8:12 pm
mtbook wrote:Thanks for the great idea! I spent the weekend building my own HEPA filter and, after some trial and error, am very happy with the results.
Since I wanted to have a removal prefilter, I decided not to add any metal grating but instead use dryer sheets. I drape the dryer sheet around the filter before I snap it in which locks the sheet in place. It's cheap and does the job pretty well. I go for the non-scent ones but you can just as easy make your home Bounty fresh :-)
Edit: Pictures!
Silicone sealant does a fantastic job air-sealing the filter to the cardboard frame (thanks for the tip, I would have never thought of using that)
Dryer sheet, cut in thirds
When the filter snaps in it clamps the dryer sheet in place
Dryer sheet snug against the HEPA filter
cant see the pics from imageshack.. :(
fetish
Postby djos » August 28th, 2011, 8:20 pm
Pics work fine here even in your quoted post
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby mtbook » August 28th, 2011, 8:22 pm
I just changed the pic hosting to uploaded attachments on the forum so that should resolve the problem. Imageshack can be goofy sometimes.
mtbook
Postby fetish » August 28th, 2011, 8:23 pm
djos wrote:Pics work fine here even in your quoted post
hmm maybe they blocked it for singapore. oh well, time to break out the VPNs...
update:
ok vpn's workin. can see the wonderful job you did with your filter. :cheers:
dryer sheets. not sure if i can find them in this part of the world but they sure look good enough to go huntin in the supermarket. :thumbup:
fetish
Postby Las Vegas » August 28th, 2011, 10:49 pm
The issue I see with the pre filter is you lose most of the surface ares of the folds of the hepa filters and it will clog much quicker than the hepa filter.
Las Vegas
Postby djos » August 28th, 2011, 10:59 pm
Las Vegas wrote:The issue I see with the pre filter is you lose most of the surface ares of the folds of the hepa filters and it will clog much quicker than the hepa filter.
I agree, the pre-filters defeat the purpose of having a HEPA filter - i've found a couple of wertiem style HEPA filters on eBay that look like they'll work well in a Neato. They have the fins much more densely packed together than the filters used so far and so should be interesting. 8)
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby mtbook » August 28th, 2011, 11:20 pm
Pre-filters are much more permeable than hepa filters, so much so that the pressure drop of adding one is negligible, Fick's Law and all that. All of the air purifiers and vacuums I've owned use pre-filters (ie. vacuum bags) as a way to prolong the life and ease the cleaning of the typically much more expensive hepa filter.
mtbook
Postby vic7767 » August 28th, 2011, 11:26 pm
Here's a Hepa filter I found on Amazon.com that was adapted to an Aero-vac Roomba bin. It can be cut and shaped to fit the Neato bin also.
Postby djos » August 28th, 2011, 11:27 pm
Good point, I just found a pic of a dyson (bagless vac) HEPA filter and it does have a pre filter, I guess because it doesn't have a bag to act as a pre filter it does need one (and by extension the Neato does too).
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby fetish » August 29th, 2011, 12:39 am
vic7767 wrote:Here's a Hepa filter I found on Amazon.com that was adapted to an Aero-vac Roomba bin. It can be cut and shaped to fit the Neato bin also.
nice find bro! i'm sure that'll cut a lot of time in the modding cuz it already has glue in the middle to hold up the shape.
fetish
Postby djos » August 29th, 2011, 12:53 am
I grabbed one of the below HEPA filters from eBay, should be a fun project. :)
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1769wt_922
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Postby Las Vegas » August 29th, 2011, 2:59 pm
MT book, I understand that a hepafilter is not nearly as permeable as the prefilter but the hepa filter has infinitely more surface area than the pre filter. That dryer sheet will clog much more quickly despite its larger pore size than the hepa simply due to the smaller surface area. Many prefilters you see have much larger pore size than a dryer sheet to catch larger debris.
Las Vegas
Postby sageman » August 29th, 2011, 3:51 pm
i can alredy see this as being the chm ball bearing mod of the xv-1x series
oh wait I already do :)
sageman
Postby mfortuna » August 29th, 2011, 4:22 pm
sageman wrote:i can alredy see this as being the chm ball bearing mod of the xv-1x series
Why would you say that? The CHM issue affected roomba reliability. The Neato HEPA filter mod is not to fix a reliability issue but to improve on the OEM filter.
Postby sageman » August 29th, 2011, 4:42 pm
not reason for doing put popularity many many many many people have that mod and i see this being no different unless filter design changes on neato's side of the woods
sageman
Postby mtbook » August 30th, 2011, 12:25 am
Las Vegas wrote:MT book, I understand that a hepafilter is not nearly as permeable as the prefilter but the hepa filter has infinitely more surface area than the pre filter. That dryer sheet will clog much more quickly despite its larger pore size than the hepa simply due to the smaller surface area. Many prefilters you see have much larger pore size than a dryer sheet to catch larger debris.
YMMV. Even after a few days of not emptying the bin, neato (on 2.1) will still tell me it doesn't detect a filter, which seems to indicate the resistance is pretty low with the prefilter+HEPA. Most of the stuff I pick up in my home is fine dust and random fiber debris which is pretty fluid and doesn't really act as a solid object blocking the filter.
I originally considered putting an air purifier charcoal prefilter in the neato but the handful I own are at least a centimeter thick.
mtbook
Postby mtbook » August 30th, 2011, 12:28 am
djos wrote:I grabbed one of the below HEPA filters from eBay, should be a fun project. :)
Awesome! Can't wait to see pictures :D
mtbook
Postby djos » August 30th, 2011, 12:36 am
I've already removed the oem material from a used filter (that was harder than I estimated!) and now I'm just waiting on my HEPA filter to arrive :D
Current Robot's:
Previous Robots:
Evolution Mint 4200
djos
Users browsing this forum: aarolar, Jani, magura, Snokia, vic7767, vjxm and 384 guests
