very poor suction on 860
Postby zak » August 18th, 2017, 10:58 am
I have a fairly new Roomba 860 that is not picking up debris. If it runs a full cycle, there is some dust in the bin, and I can feel a lot of air blowing behind the bin as it's running. The "brushes" are spinning (at least a little -- I marked them with a pen, and marks are in a new place). But any visible debris, even small crumbs on either tile or carpet, get left behind. I'm at a loss...
I did disable the cliff sensors, so it would run on my dark rug, by placing the two sensors in each box next to each other (http://www.pottsland.com/roomba/Roomba_ ... ensor.html). But everything went back together and it runs as if nothing is wrong -- it's just that there's still lint and crumbs on the floor when it's done! Maybe I did something very bad during the modification? I did the same with an older roomba years ago, without trouble...
I'm not certain if the performance got worse after the modification or if it is complete irrelevant, since I did this almost as soon as I got the Roomba.
Any thoughts would be most appreciated!
zak
Re: very poor suction on 860
Postby a1robotrepair » August 18th, 2017, 11:33 am
Once the extractors, brushes, get smooth, worn, the bot won't pick up very well. You could also run the BITs to test the CHM.
Postby zak » August 18th, 2017, 11:53 am
Thanks. The Roomba has only been run maybe 15-20 times, and the rollers (and everything) still look new.
zak
Postby vic7767 » August 18th, 2017, 12:07 pm
zak wrote:Thanks. The Roomba has only been run maybe 15-20 times, and the rollers (and everything) still look new.
a1robotrepair wrote:You could also run the BITs to test the CHM.
Did you run the BiTs (Built in Tests) and watch the CHM (Cleaning Head Module) brush deck extractors spin?
Postby zak » August 18th, 2017, 1:00 pm
I haven't yet -- was hoping the info about it being new would change the recommendation. But I will try it as soon as I figure out how to do that! I'll wade through google results unless someone has a link handy...
zak
Postby a1robotrepair » August 18th, 2017, 1:18 pm
If it's under warranty, call Irobot. The bits are identical to the 500 series except there are 2 extra, rear cliffs and bin sensors, and 3 are skipped, the charger plugged into the bot tests. You can find the 500 R3 BITs in the 500 series service manual, a copy of which is under the thread "Roomba & Scooba Info Fixes and Mods".
Postby zak » August 18th, 2017, 1:39 pm
Thanks! I put iRobot out of my mind since I voided the warranty when I disabled the cliff sensors, but I should have considered that it might possible to get support without them knowing that! I'll try the BIT and see what iRobot can do from there. I appreciate both your help.
zak
Postby a1robotrepair » August 18th, 2017, 3:16 pm
Just put it back to original before returning. A battery reset resets the no of service tests and battery data, bbox vars.
Postby Brett » August 18th, 2017, 10:01 pm
BiTs will tell you, but quicker is when it's running slide your hand under the rear of the Roomba and feel if the extractors are turning. Then you know.
Users browsing this forum: aarolar, blstz, justinall, twistdh, vic7767 and 415 guests
