Scooba 380
Re: Scooba 380
Post by vic7767 »
Yes, I use a USB-A to Micro-USB. When the cable is connected between the 450 and a PC when you press Clean once the PC should create a COMM port.
CactusJack
Re: Scooba 380
Post by CactusJack »
Thanks for all of your help!
Cactus
CactusJack
Re: Scooba 380
I picked up a second 450 and a new cable. Still getting the same results. Scooba reports firmware version, battery condition, & etc. But will not take any input from computer. What terminal program are you using and what settings on the baud rate, parity and so forth are you using?
Thanks Cactus
Re: Scooba 450
Post by vic7767 »
Something I failed to mention is that you will need the iRobot Scooba450 update installer program that is used to build a COM port. Send me your email (in a PM) and I'll send you a copy to install on your Win pc.
The file is an .exe type file and to send it I change the .exe to .txt so it will send to you. When you get the file, change the text from .txt back to .exe
CactusJack
Re: Scooba 380
I sent you a private message with my email address in it. (I hope!) If you didn't get it I will try again.
Thanks again!
Re: Scooba 380
Post by vic7767 »
Did not receive a PM from you.
CactusJack
Re: Scooba 380
Hopefully I did it right this time!
Re: Scooba 380
Post by vic7767 »
:cheers:
