Moderator: robotreviews
cbalmain wrote:I've had a weird problem with my Scooba 5800. I charged it up, but whenever I turn it on it gives 5 tones going up, then 5 tones going down, and then all the lights flash in sequence, from left to right. It seems to be stuck in this mode. I've tried removing the battery, but as soon as I put it back in the same thing happens.
RoombaExchange wrote:Cbalmain, you can do a search for scooba stuck in test mode and come up with several similar issues involving the Scooba control panel and the button contacts. The contacts or communication tether/cable are what fail, moisture can be a contributing factor.
A few options for you are to disassemble the scooba down to the control panel and either replace it or if you do not feel comfortable with doing the repairs you can ship it in to us to do the repair work for you. Either option will cost less than a replacement and if the repair costs through us exceed our recommended repair budget of $125 then you will have the option to trade it in.
http://www.roombaexchange.com/proddetai ... 492&cat=40
tum wrote:. . . I used isopropyl alcohol to clean the contacts and then used a conductive pen to redraw the contacts that were damaged.
RoombaHolic wrote:tum wrote:. . . I used isopropyl alcohol to clean the contacts and then used a conductive pen to redraw the contacts that were damaged.
Great save . . . and just where does one get a "conductive pen"???
007bond-jb wrote:You were rite I cut the clean switch plastic & must have cut to deep. its no longer in diag & says check tank or brush with them removed. but it will not start cleaning when I push clean. Looks like I'm gonna have to buy a new control pannel
Why does the curcuit have a black coating or outline?
I talk a bit about those black conductor-strips on this page, about half way down.007bond-jb wrote:...Why does the curcuit have a black coating or outline?
